New member, guess I had to start this?
Started by Yotaoverland, February 24, 2015, 01:51:17 PM
Yotaoverland
Just a new member in search of knowledge about the toyota I'm about to get.
1980 pickup LWB
22reperformance 22r
L-52 5spd
4.7 Tcase
Detroit Trutrac
Yotaoverland
Thank you, Toe.
So I know I should put this in the engine tech portion of the forum but I located a guy who has a 1985 22r (said it was a base model truck, therefore it has the carb). I'd like to make it a 22re. I assume that all I'd need would be the EFI intake from one, the higher output fuel pump and tank, and the wiring harness?
1980 pickup LWB
22reperformance 22r
L-52 5spd
4.7 Tcase
Detroit Trutrac
blackdiamond
Quote from: colezombie on February 24, 2015, 03:10:52 PM
Thank you, Toe.
I think you may find that the EFI swap is a challenge. Any reason to not just wait to find one that is EFI already?  Do you care about he independent front suspension vs. solid axle?  I wheeled/drove a non-EFI 85 truck and had minimal issues even at high altitude and odd angles.
Yotaoverland
Oh, I was wanting to put it in a 1980. But now I may just wait for an already EFI engine to pop up.
1980 pickup LWB
22reperformance 22r
L-52 5spd
4.7 Tcase
Detroit Trutrac
