Author Topic: A340H to A340F 91 4runner  (Read 3265 times)
Worstenemy453
  • Member since Jan '15
« on: Jan 30, 2015, 10:21:20 AM »
I've been doing a lot of searching but haven't found any real answers that apply to me.
I have a 91 4runner 3.0 V6. A340H.  I want to consider an A340F swap simply to improve on road performance and economy. I want to run the stock transmission and transfer case and simply just have them separated as the F set up comes. I won't ever care about lower tcase gears or dual units and this is just a daily driver and see occasional light duty off road use.
Is this a simple swap where the parts all simply swap over or will there be additional adaptors or customizations need and what year A340F should I look for?  Does the F still share the same failure prone solenoids that the H sees being the same basic Trans ?
I've searched and there is a lot of information out there but mostly on swapping the run dual t cases and what not and doing this swap with engine swaps that I don't need to consider.
R.DesJardin
  • Turtle Points: 680
  • Male Posts: 489
  • Member since Mar '08
    • RADesigns Products LLC
Re: A340H to A340F 91 4runner
« Reply #1 on: Jan 30, 2015, 03:27:13 PM »
A 3.4 trans would bolt up since it is of the same engine family. I think all of the 3.4 have driver drop transfer cases. You'll have to sort this out what to do.
R.DesJardin
Worstenemy453 [OP]
« Reply #2 on: Feb 01, 2015, 08:05:46 PM »
I don't want to deal with that much craziness. What about the AW4 jeep swap or is there a way to just run a divorced case with the stock transmission.
94Runna
  • Turtle Points: 453
  • Male Posts: 83
  • Member since Feb '17
  • 253 <--> 808 Instagram: Hapa_4
« Reply #3 on: Feb 09, 2017, 12:07:51 PM »
lets open this thread back up, what did you end doing with the 340F swap? I believe I got a 340F from a 95 t100 with the 3.0 (I think that only because the t-case is pass drop).
Anyone know if the speed sensor for the TCU will work for my once 340H set up?
Mudder
  • Turtle Points: 3487
  • Member since May '15
« Reply #4 on: Feb 09, 2017, 12:19:00 PM »
Have you read through this?
http://www.4x4wire.com/toyota/tech/autocrawler/
94Runna
  • Male Posts: 83
« Reply #5 on: Feb 09, 2017, 12:26:29 PM »
yes, I read through that and have it printed out as well. the only thing I'm stuck on is whether or not I have to modify my tail shaft housing for the speed sensor.  :headscratch:
94Runna
  • Male Posts: 83
« Reply #6 on: Feb 09, 2017, 12:58:04 PM »
if the A340F I  have came out of a 95 t100, I don't need to modify the housing right?
94Runna
  • Male Posts: 83
« Reply #7 on: Feb 09, 2017, 12:58:43 PM »
aww crap, wrong post  :outtahere:
Last post Jan 19, 2004, 12:18:52 AM
by 84runner
Last post Jun 06, 2007, 09:30:35 AM
by Marc P
Last post Mar 02, 2010, 10:15:45 AM
by BeerHat
Last post May 13, 2010, 07:46:34 AM
by SocalWheeler71
Last post Feb 26, 2019, 07:13:34 AM
by R.DesJardin
