Author Topic: Dual Case Drain and Refill  (Read 1320 times)
84Flatbed
  • Turtle Points: -196
  • Member since Jun '13
« on: Dec 06, 2014, 04:02:24 PM »
Ill be changing the fluid in my cases soon and wasn't sure if I should pull the plug from from the adapter (MC) or just the plug on the rear case.
81 shortbed
  • Turtle Points: -5
  • Male Posts: 329
  • Member since Nov '13
Re: Dual Case Drain and Refill
« Reply #1 on: Dec 06, 2014, 04:33:04 PM »
Both
84Flatbed [OP]
« Reply #2 on: Dec 06, 2014, 05:43:41 PM »
Thanks. Then just fill from the top, through the shifter hole on the rear case, I believe the front case is forward shift.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #3 on: Dec 06, 2014, 06:12:35 PM »
If you are filling through the rear, after it starts coming out the fill hole let it sit a bit so it will equalize between the two cases. Then continue filling.
Last post Jun 09, 2005, 09:24:36 PM
by Joe King
Last post Apr 11, 2006, 10:32:22 PM
by wa4x4
Last post Jul 20, 2007, 01:09:14 PM
by BigMike
Last post Sep 22, 2008, 08:31:28 PM
by Highlander
Last post Apr 10, 2016, 01:36:33 AM
by kneedownnate
