Author Topic: '99 TACOMA E-LOCKER QUANDARY  (Read 1211 times)
hometowngarage
  • Male Posts: 3
  • Member since Nov '14
  • Dances with Taxes!!
« on: Dec 05, 2014, 02:26:07 PM »
So there are 3 switches on the OE T-case; 4x4, Low Range, and Neutral.  I am using an old gear box with one switch; 4x4 for the dash light.  What is the best way to wire up these OE connectors so that the dash light and my E-Locker still work correctly?  I know that you can just ground the Gray wire to get the E-Locker to work in Hi or Lo, but I just want the light to come on when I am in 4X mode.  Any takers?  Thanks
Silence is Golden, Duct Tape is Silver!!!
BigBluePile
  • Turtle Points: -147
  • Male Posts: 229
  • Member since Feb '13
  • Conquering the toughest malls.
    • YT
    • Buy me some coffee
Re: '99 TACOMA E-LOCKER QUANDARY
« Reply #1 on: Dec 05, 2014, 10:40:38 PM »
Just find the signal wire from the elocker computer and wire it into the cluster harness.....?
'86 4Runner SR5 TRD 5VZ-FE
...slightly modified from OEM...
slander
  • Turtle Points: -173
  • Member since Sep '07
« Reply #2 on: Dec 22, 2014, 09:57:48 AM »
I swapped a lefty into my taco and here how i got my ADD "hub" to work without using the tcase switch.  I first did the gray wire mod for the locker, all indicators on the dash work for that.  As for the ADD and 4wd dash light switch, all i did was cut the harness off the 4wd indicator switch that's on the pax side of the tacse and put a two way switch in there that i mounted on the dash.  ADD works and the factory 4wd light worked.  I also remember reading that the gear drive switches can be wired into the taco factory 4wd wiring.
2002 taco ext cab trd, 3.4 5spd.  255/58/16, OME 882s, all pro bumpers f/r, Inchworm front plate, crawler mounted with an mc07 XD to an inchworm lefty, marlin 4.7 gears, marlin 30spline output, RAD designs triple sticks.  Fj 80FF rear with a spartan locker.
Last post Mar 03, 2004, 03:04:59 PM
by conflict
Last post Dec 07, 2006, 04:27:34 PM
by 79coyotefrg
Last post Nov 13, 2005, 01:26:57 PM
by AJ Johnson
Last post Jun 10, 2006, 03:36:57 PM
by 85toychris
Last post Oct 17, 2012, 02:43:23 PM
by THK Matt
