Author Topic: Having a problem with fresh dual case build HELP!!  (Read 2279 times)
toyotaporvida
  • Member since Apr '09
« on: Sep 01, 2014, 06:01:42 PM »
Parts in cases.
 Marlin dual adapter
 Marlin front and rear 30 spline outputs
 Trail gear 4.70 gears
 Trail gear twin stick
So I recently put the cases together. I took her out for a test drive on the street and she was fine. Took her out on some local trails for about 2hrs. When I got back on the street I noticed a whine coming from the rear case. It sounded like the left rear shifter wanted to go in to neutral. So what I did was slightly bump it and hold it between high and neutral and the noise goes away. But when i put it back in to its regular position of high the noise comes back.. It does it with the tranny in neutral costing too. I read on line about guys saying I need a cv shaft but I dont think that's the problem since I took the drive shaft off and it still does it. So i just drained the oil  and i do have some metal in the oil. Not good at all.. Any of you guys ever have this problem. Any help is appreciated.  Thanks
daniresch
  • Turtle Points: 930
  • Male Posts: 761
  • Member since Apr '11
Which drive shaft did you take off front or back?
And how much metal do you have in the oil? a little is normal while breaking in new gears, its highly recommend you replace the oil after ~100 miles when installing new gears.
toyotaporvida [OP]
Took off rear drive shaft.  There was no big chunks of metal just small shavings. Ill be taking case apart this week to see what went wrong.
Nation
  • Turtle Points: 1141
  • Male Posts: 1,565
  • Member since Mar '13
  • @nationallmotors
 :inthedark: keep us posted
toyotaporvida [OP]
So I tore the case apart last night. The 23 spline input gear is missing tiny pieces on the side and the bearing might be no good. I tried taking the 2wd/4wd shift hub off the output shaft and it won't come off. Any ideas?
hunmetal
  • Member since Jul '11
Sounds like that :pokinit: broken
Last post Oct 03, 2010, 08:54:32 PM
by John Doe
Last post Aug 29, 2007, 03:48:51 PM
by Redeyejedi
Last post Nov 27, 2010, 07:50:44 AM
by 4RunnerChevy
Last post Jun 28, 2011, 01:51:05 PM
by dweinberg01
Last post Mar 10, 2017, 10:57:44 PM
by Crunchy Taco
