Author Topic: gm 1 wire alternator  (Read 3524 times)
81 shortbed
  • Turtle Points: -5
  • Male Posts: 329
  • Member since Nov '13
« on: Jul 26, 2014, 09:22:37 AM »
I've had a charging problem on my 81 since I bought it. messed with it some but never got it right. a couple weeks ago I swapped to a gm 1 wire. I ran the hot wire to the starter post and the ground to the frame. the alternator is new and is only putting out 11.5-12 volts. my question is- did I wire this right? I could have got a bad alt but want to make sure I got it wired properly before I take the alt off to get tested.  :headscratch:
megaphoneman
  • Turtle Points: 677
  • Member since Nov '04
Re: gm 1 wire alternator
« Reply #1 on: Jul 26, 2014, 09:44:35 AM »
Rev it and measure, isnt that the problem with one wires? It wont kick in till higher rpms..
Blaaaahhhhhhhh
81 shortbed [OP]
  • Turtle Points: -5
  • Male Posts: 329
« Reply #2 on: Jul 26, 2014, 10:17:40 AM »
i'll try that. did I wire it correctly?
OVRAROK
  • Online Silver Turtle Award
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
« Reply #3 on: Jul 26, 2014, 10:57:18 AM »
when I buy alt from parts store, I will have them test it right then, more than one time have they tried to sell defective part. that way you can rule out alt as being problem
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,141
  • Member since Sep '08
« Reply #4 on: Jul 26, 2014, 02:17:02 PM »
check out madelectrical.com they have a fantastic write up, all the info you need.
66cobra
  • Turtle Points: 34
  • Member since Mar '08
« Reply #5 on: Jul 30, 2014, 02:56:51 PM »
i have a 4.3 swap and have a gm style  1 wire from power master, 200 amp wired direct to battery which has never had problem. running it 3 years. the alt charge @ 1200 below that output low. has to do with the internal switching.
it's not me, it's you
Stew_pedaso
  • Turtle Points: 74
  • Male Posts: 102
  • Member since Jun '14
« Reply #6 on: Aug 11, 2014, 07:40:29 PM »
Why did you need the ground if it's 1 wire alt. mine is straight to the battery. Holds 13.1 at idle and 14.1 with a little rev
Placer county crawler- Vice President
KK6QOJ
My build thread
http://board.marlincrawler.com/index.php?topic=97287.0
VincentVanPwn3d
  • Male Posts: 28
  • Member since Jan '11
    • Buy me some coffee
« Reply #7 on: Nov 03, 2014, 06:00:54 PM »
Hot wire to starter???? It should have one power wire going from the alternator to the battery and the alternator should be grounded to the motor through the alternator bracket. The motor should be grounded to the firewall. Check and clean sand your grounds. But you probably toasted your starter if you wired it to it.
86 4runner
22re
Last post Mar 16, 2007, 08:43:51 AM
by intheworks
Last post Sep 06, 2010, 09:38:03 PM
by locked 4x4
Last post Apr 20, 2015, 10:08:50 PM
by GreenYoterKrawler
Last post Nov 16, 2016, 06:34:30 AM
by mudmaster
Last post Feb 15, 2017, 09:55:14 AM
by mudmaster
