Author Topic: OVRAROK. My 87 4runner  (Read 181940 times)
Dingman.
  • Turtle Points: 1083
  • Male Posts: 3,441
  • Member since Oct '08
Re: OVRAROK. My 87 4runner
« Reply #1170 on: Jun 24, 2019, 09:49:32 AM »
Now you need to link it and have the shock hoops poking through the hood too :bling:
OVRAROK [OP]
  • Turtle Points: 23996
  • Male Posts: 2,970
  • Member since Dec '10
« Reply #1171 on: Jul 02, 2019, 10:15:03 AM »
Steering is done. Just need to make another hole in hood. Have another hood on its way...
Sent from my SM-G975U using Tapatalk
mudmaster
  • Turtle Points: 2974
  • Male Posts: 2,714
« Reply #1172 on: Jul 02, 2019, 10:16:59 AM »
Got er to bleed?
Time to go wheelin!
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1173 on: Jul 02, 2019, 10:19:21 AM »
Got er to bleed?
Yep... first try...   :thumbs:
gnob
  • Turtle Points: 486
« Reply #1174 on: Jul 02, 2019, 10:51:37 AM »
Can you seriously not fit the reservoir under the hood?
hold this. . .
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1175 on: Jul 02, 2019, 11:04:08 AM »
I could fit it under, but the reservoir would be lower then pump.
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1176 on: Jul 02, 2019, 11:04:49 AM »
Hood is done...
gnob
« Reply #1177 on: Jul 02, 2019, 11:19:53 AM »
Only the fluid level needs to be above, not the whole thing.
hold this. . .
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1178 on: Jul 02, 2019, 11:28:47 AM »
Well shoot..
Now you have me thinking.., I may try and lower before hood gets here..
gnob
« Reply #1179 on: Jul 02, 2019, 11:43:47 AM »
Check out swilsons 4runner
hold this. . .
gnob
« Reply #1180 on: Jul 02, 2019, 11:48:44 AM »
I know its not an RZ, but how i did mine.
hold this. . .
mudmaster
  • Male Posts: 2,714
« Reply #1181 on: Jul 02, 2019, 12:34:51 PM »
Mine is under the hood
Time to go wheelin!
mudmaster
  • Male Posts: 2,714
« Reply #1182 on: Jul 02, 2019, 12:35:39 PM »
I had problems with the tube clamp sliding too. Mine is now welded on.
Time to go wheelin!
  • Turtle Points: 6074
  • Male Posts: 3,497
    • emsvitil's album
« Reply #1183 on: Jul 02, 2019, 04:57:59 PM »
You could make a hood scoop...……….
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1184 on: Jul 19, 2019, 10:29:40 AM »
After speaking with PSC. I decided for the time being. I will keep my reservoir where its at...   it works great, with no problems. He explained to be that the pump is great at moving fluid, but if its constantly has to pull the fluid. It will shorten the life of pump..after staring at it for awhile, I think that the chilkat PS pump bracket can be improved on.
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1185 on: Jul 19, 2019, 10:31:16 AM »
Here's a couple pics..
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1186 on: Aug 07, 2019, 02:14:17 PM »
My front driveshaft was hitting my exhaust. So I made another exhaust pipe.
LittleSteve
  • Turtle Points: 19
  • Male Posts: 797
  • Member since Jan '14
« Reply #1187 on: Aug 07, 2019, 03:22:04 PM »
I know a guy that used baking trays to cover up stuff poking through his hood, i can find pictures...
Refusing to fit in or comply.
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1188 on: Aug 22, 2019, 10:48:43 AM »
Finally got around to installing new clutch hydraulic system. New master, and slave. Painted with brake caliper paint. Made a -3 AN stainless steel line for it.
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1189 on: Aug 22, 2019, 10:50:48 AM »
Just waiting on some ATE dot 4 fluid..
swilson
  • Male Posts: 284
  • Member since Aug '11
    • My 1966 FJ40 Build Up
« Reply #1190 on: Aug 31, 2019, 07:23:27 PM »
Hood is done...
What is going on here???
3-4" is not going to have any significant impact on the life of your pump... But totally destroys the clean look you had going
Sorry to be negative. I really appreciate clean rigs
Scott Wilson - TLCA #5261
1966 FJ40 [sold] - Click for Build thread
1988 3RZ 4Runner - Click for Build thread
1964 FJ40 TBD
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1191 on: Aug 31, 2019, 07:52:22 PM »
I'm making a new PS bracket. New one should allow pump to be mounted lower. So I can lower reservoir. Those pics are of my first attemp..right now reservoir is barely poking out.. :thumbs:
swilson
  • Male Posts: 284
« Reply #1192 on: Aug 31, 2019, 10:13:49 PM »
I just took a look through your build thread... You do great work!
1964 FJ40 TBD
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1193 on: Sep 01, 2019, 03:05:42 AM »
Thank you sir...
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1194 on: Dec 19, 2019, 08:46:25 AM »
Moved my bank 1 o2 sensor..gained almost 3 mpg.
swilson
  • Male Posts: 284
« Reply #1195 on: Dec 19, 2019, 08:49:58 AM »
How/why did you decide to move it?  Did you dyno the truck to get the HP number?
1964 FJ40 TBD
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1196 on: Dec 19, 2019, 09:03:01 AM »
When I built exhaust, I wasn't thinking to much about location..afterwards..I felt that my 4runner was running rich..I thought what the heck. I'm going to move it as close to exhaust manifold. As far as knowing HOW I know mileage has improved..is i have scan gauge permanently mounted where altimeter used to be.. I dont drive on hwy much..but I went from 13 mph avg to 16.8...
swilson
  • Male Posts: 284
« Reply #1197 on: Dec 19, 2019, 09:12:20 AM »
Best I can get on my swap is 14mpg...  Miles divided by gallons, not scan gauge.  I thought it would be a little better, not that it really matters. It'll go across the Rubicon twice in a tank or gas That's good enough
1964 FJ40 TBD
OVRAROK [OP]
  • Male Posts: 2,970
« Reply #1198 on: Dec 19, 2019, 09:16:26 AM »
You on 37s?.. I'm on 15% left 35s..getting ready for new rubber..38s. Maybe I'll lose a few mpg,
swilson
  • Male Posts: 284
« Reply #1199 on: Dec 19, 2019, 09:43:26 AM »
Yes 37s.  3RZ does well with them, except for long hills at freeway speeds
1964 FJ40 TBD
