Author Topic: Alternator Terminal Identification (Charging Issue)  (Read 9584 times)
82juguete
  • Turtle Points: 5
  • Member since Jan '07
« on: Mar 17, 2014, 09:34:10 PM »
I've been plagued by an ongoing charging issue. Truck is a 1982, originally had a 22r, but I swapped to a 1980 20r. When I swapped the motor I kept the alternator from the 22r so that it stayed kosher with my existing regulator/chassis loom, etc.
The regulator has the irregular oval plug, with 5 blades. I'm hoping someone has the same setup and can identify for me the wire that I've realized was torn clean off at some point. The attached diagram should help explain what I'm talking about. Note the wire colors that I was able to best identify don't jive at all with any of the FSM wiring diagrams I have referenced.
I'm hoping someone can help me out with a color, or even better, the destination of where this wire goes (in regards to the alternator or vehicle loom)...Thanks.
« Last Edit: Mar 21, 2014, 08:43:30 AM by 82juguete »
82juguete [OP]
  • Turtle Points: 5
Re: Voltage Regulator Wire Identification
« Reply #1 on: Mar 18, 2014, 09:50:41 AM »
I'm far from a wiring guru, but it seems to me that the attached schematic shows my configuration. External reg with 5 wires. Correct me if I'm wrong on this, but I'm interpreting the wire colors to be Red, Yellow, White and Green, meaning the one I'm missing is (B) or black (or blue?)
This diagram also shows that it's one of the integral wires going directly to the alternator. This would be a clear cause of failure to charge if this is the case. I will have to peek inside the wire loom and see if the mystery wire broke off inside somewhere... seems like a long shot but we'll see.
Is my interpretation completely off on this?
82juguete [OP]
  • Turtle Points: 5
« Reply #2 on: Mar 18, 2014, 02:10:52 PM »
I just took a quick look and I noticed that the wire in the pigtail coming off the regulator that lines up with the one I'm missing is black. (All others are white with colored indicator stripes)
I'm starting to thing the missing wire may be a ground.
Can anyone confirm this?
tgmaul88
  • Turtle Points: 30
  • Male Posts: 985
  • Member since Feb '12
  • Im still alive
« Reply #3 on: Mar 18, 2014, 06:33:38 PM »
black ground, ill go look at mine
82juguete [OP]
  • Turtle Points: 5
« Reply #4 on: Mar 18, 2014, 07:03:26 PM »
Thanks. Broken ground would be the best case scenario.
82juguete [OP]
  • Turtle Points: 5
« Reply #5 on: Mar 20, 2014, 02:28:56 PM »
I temporarily grounded the wire in question. Either the wire is not a ground or the problem lies elsewhere.
I put a fully charged battery into the truck and tested the voltage. 12.93 volts.
Started the engine and checked the battery voltage while it ran. 12.5 volts.
Increasing the RPMs, blipping the throttle had zero effect on this number, so I'm still searching.
82juguete [OP]
  • Turtle Points: 5
« Reply #6 on: Mar 21, 2014, 08:17:43 AM »
Did some more testing. Pulled my attention away from the regulator at the moment.
The alternator doesn't appear to be charging (no magnetic field on the back of the case when running). But I have no reason to believe it's bad yet.
Took the voltmeter to the harness plug that the alternator plugs into expecting to find and ignition hot (ign), a constant hot (sense) and the lamp wire.
All that showed on the meter was the ignition hot.
My plan now is to run a jumper wire from the battery to the sense terminal on the alt so that I can truly test the alternator's functionality. Problem is, I can't determine which terminal is which on the back of the alt. For the record, my plug type is like the one shown below.
82juguete [OP]
  • Turtle Points: 5
« Reply #7 on: Mar 21, 2014, 08:19:19 AM »
Could someone help me label the above with (L) Lamp, (S) Sense, and (I) Ignition? Thanks.
82juguete [OP]
  • Turtle Points: 5
Found another clue and answer to my above question. I'm going to jump power to that sense terminal and see if the alternator operates correctly then. That should tell me if a fusible link blew on that sense wire or something.
GONZO97
  • Turtle Points: 48
  • Male Posts: 612
  • Member since Apr '09
  • travel the path less taken
    • Christian's Mattress Xpress
so whats the verdict? I know you sent me that video today but how are things going? update!!!
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
Last post Nov 28, 2005, 03:05:11 AM
by Resist
Last post Apr 24, 2008, 01:13:59 PM
by 79coyotefrg
Last post Aug 05, 2009, 02:29:56 PM
by Yoat Goat
Last post May 13, 2011, 10:11:34 AM
by Cheesemaker
Last post Jun 26, 2012, 05:59:09 AM
by tgmaul88
