The first thing that you might look at is the fuel pump. If the fuel is 2 years old, Remove the fuel tank skid plate, and drain the old fuel. You can purge the system by removing the fuel line from the fuel pump, and slightly pressure the tank with a rag and air hose until fuel reaches the pump. If that doesnt work, pull the fuel tank and check the fuel pickup screen. Keep us posted, Good Luck!
