Author Topic: Heater hose question  (Read 1883 times)
84Flatbed
  • Turtle Points: -196
  • Member since Jun '13
« on: Jan 22, 2014, 07:10:23 PM »
Why is more than one piece used where the heater hose connects to the metal line? As far as I know this is how they came from toyota.
Also, I have a flush T a few inches past the bend above, not shown in the pic, and was going to look for a 90 deg. hose to replace the multi piece one from the T to the metal pipe. If anyone else has done this and has a part number that  would work that would be great.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: Heater hose question
« Reply #1 on: Jan 22, 2014, 09:45:34 PM »
I don't have a two piece in my 85 4Runner, plus the two hose clamps at the bottom are not oem
84Flatbed [OP]
« Reply #2 on: Jan 23, 2014, 12:55:19 PM »
Correct, the 2 lower clamps have been replaced, the top one should have been too I have to crank it down hard to keep it from leaking. The reason I believe it to be factory is that I have seen pictures of others who have the same setup as mine, also this quote is from 22re performance heater hose kit "Heater core to pipe (long enough to eliminate the extra “extender” 4 clamp ordeal for you 4X4 guys)"
  • Momentum Man
  • Lego Enforcement
« Reply #3 on: Jan 23, 2014, 03:18:50 PM »
Guess I have the extended eliminator hose. :dunno:
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #4 on: Jan 23, 2014, 03:41:11 PM »
My 86 never had 2 pieces there.
I wonder if it's a 2WD vs 4WD difference.
Originally the 2WD hose was too short for 4WD trucks and they just added an extender until they made a longer 4WD hose.....
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Momentum Man
  • Lego Enforcement
« Reply #5 on: Jan 23, 2014, 03:45:52 PM »
Hmmm, that could be, since his is an 84 and mine is an 85.
84Flatbed [OP]
« Reply #6 on: Jan 23, 2014, 05:53:50 PM »
So it sounds like getting the hose for an 85+ might do the trick.
herpestes
  • Turtle Points: 190
  • Member since Jan '07
« Reply #7 on: Jan 25, 2014, 04:54:24 PM »
84 heater hose
  • Momentum Man
  • Lego Enforcement
« Reply #8 on: Jan 25, 2014, 05:51:56 PM »
Now that look factory with the permanent clamp in the middle.
  • Momentum Man
  • Lego Enforcement
« Reply #9 on: Jan 25, 2014, 05:58:52 PM »
Did a quick search and I believe that small hose is called an auxiliary hose.
Last post Dec 12, 2004, 10:44:50 AM
by Fireimp141
Last post Jun 04, 2008, 07:01:25 AM
by blackdiamond
Last post Dec 04, 2008, 06:29:53 PM
by 94MtnYote
Last post May 29, 2014, 07:52:21 PM
by TMex
Last post Jan 17, 2017, 04:46:21 PM
by Cavu2usf
