Author Topic: Marlin Crawler Dual case setup Locking out  (Read 2719 times)
86sasyotanh
  • Member since Jan '14
  • Crawling in the Trees
« on: Jan 15, 2014, 06:39:24 PM »
I have a dual setup and if I shift from 4x4 low low and shift the top shift toyota unit from low to high, it locks the toyota unit in neutral. Any ideas on why it does that? Is that supposed to happen?
1986 Toyota 22r 5 speed SAS Dual Cases Welded rear 36x12.50x15 tsl flatbed
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: Marlin Crawler Dual case setup Locking out
« Reply #1 on: Jan 15, 2014, 07:12:53 PM »
Is this a new install?
  • Administrator
  • Turtle Points: 2159
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #2 on: Jan 16, 2014, 06:19:42 PM »
Did you trim the required 1/2" off the driver's side shift rail of your transfer case?
Here is a picture of Marlin himself doing this, quoted from Loki's build thread,
Cover the counter shavt and coupler bearings with a shop rag (Marlin tucked it behind the snap-rings) to prevent metal shavings from going into the bearings/case and with a high powered cutoff whell, get to crackin. Make sure you shift it into hi. it should be about 1/2" to cut off.
Key point to note is to shift the t/case into high range, either 4WD-High or 2WD-High, to expose more of the shift rail for an easy cutting process.
Let us know if you did this or not, thanks!
  • Momentum Man
  • Lego Enforcement
« Reply #3 on: Jan 16, 2014, 06:26:12 PM »
That's why I asked if this was a new install
86sasyotanh [OP]
« Reply #4 on: Jan 17, 2014, 06:58:22 AM »
I didn't install it I just got the truck an it was installed by the previous owner.
  • Momentum Man
  • Lego Enforcement
« Reply #5 on: Jan 17, 2014, 11:50:11 AM »
You should check to see if the shift rod was trimmed like Big Mike mentioned. Sucks when you have no idea if it was done since you will have to pull the tcase off to find out.
  • Momentum Man
  • Lego Enforcement
« Reply #6 on: Jan 17, 2014, 12:47:34 PM »
As a thought if you know the PO's # give him a call to find out if he cut the rail and how much he cut.
Last post Dec 23, 2006, 07:17:45 PM
by 85 and still running
Last post Aug 09, 2011, 09:42:04 PM
by FRANKENYOTA91
Last post Dec 24, 2007, 11:54:59 AM
by Lizard_lips
Last post Aug 25, 2017, 10:12:21 PM
by 300k
Last post Jan 15, 2010, 01:36:07 PM
by troyman
