Author Topic: Zip locker question  (Read 1831 times)
Rockfish 91XTRA
  • Member since Oct '10
Zip locker question
« on: Nov 16, 2013, 02:08:06 PM »
Hey guys, I'm installing a complete 3rd member that I bought from MC.  It's a toyota v6 with 4.88s and a zip locker.  I'm installing this in a 91 star cab v6 p/u
The 3rd member came with a plug in the ABS port.  Should I remove the plug and install the ABS sensor or do I have to scrap the ABS with the new diff?
Need some advice ASAP.  Need to get this back together tomorrow
thanks!
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: Zip locker question
« Reply #1 on: Nov 17, 2013, 08:19:17 AM »
Does the ring gear have a tone ring on it? If not you will lose the ABS, it may also set some codes.
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
« Reply #2 on: Nov 17, 2013, 08:59:01 AM »
I thought the tone rings were on the outer ends of the axles shafts.  Is that only newer models?
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
Rockfish 91XTRA [OP]
« Reply #3 on: Nov 17, 2013, 11:07:57 AM »
The sensor on my 91 is located at 12 o'clock on the diff housing, just over the ring gear.  I don't see anything that looks like a tone ring.  Then again I've never seen a tone ring.
Any help is appreciated!
Goldrush
  • Turtle Points: 145
  • Male Posts: 1,381
  • Member since Jan '10
  • wheelin!!
« Reply #4 on: Nov 18, 2013, 08:34:54 AM »
Just take that freeze plug out and install your ABS sensor.
« Reply #5 on: Nov 18, 2013, 04:25:58 PM »
Roger that.  I popped the plug out last night and plugged in the sensor.  I haven't had tested it but after lookin everything over closely I couldnt see any difference between the new and old diff.
Thanks guys!
ecrum428
  • Turtle Points: 15
  • Member since Sep '13
« Reply #6 on: Nov 19, 2013, 03:56:05 AM »
Must be that the sensor picks up the teeth on the ring gear as the tone ring.
OOPS
  • Male Posts: 2,561
« Reply #7 on: Nov 19, 2013, 02:23:35 PM »
I thought there was a tone ring on the ring gear.
Last post Jan 18, 2005, 10:12:10 PM
by kneedownnate
Last post Jul 30, 2006, 10:11:44 AM
by Rocksurfer
Last post Aug 24, 2006, 06:42:02 PM
by Ewong
Last post May 14, 2009, 09:19:59 AM
by Qtip
Last post Mar 18, 2012, 09:21:22 PM
by Yota87Truck
