Check your fuel pump. I'm assuming its mechanical, pull the inlet line off the carb, stick it in a bottle of some sort and crank it over. If you have fuel to that point, then you know its an issue with the carb, if not then its most likely an issue with the pump! Unless of course you have a pinched fuel line somewhere...
![Beer Chug\'n :beerchug:](https://board.marlincrawler.com/Smileys/marlin/beerchug.gif)
