Author Topic: 1983 4x4 IFS Truck project, ditch the solid axle!  (Read 33572 times)
cowsinblack
  • Turtle Points: 60
  • Member since Jan '14
Does the independent suspension keep the center of gravity more in the middle of the truck vs. solid axles that kinda shift the truck body from side to side?
« Last Edit: Apr 09, 2014, 10:06:29 PM by cowsinblack »
R.DesJardin [OP]
  • Turtle Points: 680
  • Male Posts: 489
  • Member since Mar '08
    • RADesigns Products LLC
Please don't get all scientific and technical on me. CG, roll center, etc.
I just want more ground clearance and more wheel travel for dodging rocks and running in the snow. Neither are fast or really to critical for cg. Oh, and I love building stuff.
R.DesJardin
ryantowry_81
  • Turtle Points: 185
  • Male Posts: 474
  • Member since Dec '12
  • Chief Mischief Officer at High Octane Spirits LLC
    • High Octane Spirits
    • Buy me a drink
Not building a long travel setup, not a pre-runner, snow wheelin and mountain trails is the goal use. Not saying the same idea couldn't be use with higher end parts. When i did research most feedback is either desert fast or Ultra4 design. I do neither and most of what they build for is a LS* something something. Just trying to get a little more clearance, a little more travel and a better ride all in all. I hope.
I get what you are saying here. i originally was planning on a fun non racing truck too that could be smooth over rough terrain up to 30 MPH nothing too fast just be able to run fire roads and gravel at a decent speed.
I was just using their designs and technology and trying to find a cost effective way of accomplishing my goal.
another point i researched alot is torsion springs. I think most people give them a bad rap because they are less tunable than coilovers but they can perform pretty decent with the right shock valving. i found that as a way to achieve my objectives more cost effectively than coil overs.
just another point to think about.
R.DesJardin [OP]
  • Male Posts: 489
Moving into a bigger shop so this will get going again. Right now I'm so cramped up I can hardly turn myself around let alone finish this buildup.  :greengrin:
R.DesJardin
ryantowry_81
  • Male Posts: 474
    • Buy me a drink
Yeah I know the feeling. My garage has turned into kitchen remodel central instead of rig building. Sure puts a cramp on projects. How big is the new shop?
R.DesJardin [OP]
  • Male Posts: 489
24 x 48+
R.DesJardin
ryantowry_81
  • Male Posts: 474
    • Buy me a drink
Yeah mine is 24x42. Wish it was deeper( mine is 42 wide) sometimes but on toyota's it is not usually a problem
R.DesJardin [OP]
  • Male Posts: 489
Well I have not worked on this lately, I needed to modify my mount sub-frame and had to wait on the plasma tale at work to get setup and running. Then I went on vacation, then I took a job back in Washington State so I've moved back into my house there with the 24x48 shop and start the new job Aug 4. I did 3 trips of stuff 2 pickup and trailer and 1 26ft UHaul and trailer to get everything here. The Toy is still sitting on the trailer and I hope to get it unloaded this weekend, next is getting the shop set back up to a functional state. And then the fun will begin.
R.DesJardin
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
Welcome back to Washington! :beerchug:
R.DesJardin [OP]
  • Male Posts: 489
The Toy is back home, parked inside in the shop where it belongs. I now can get a started back into this.
R.DesJardin
SKULLYOTA
  • Turtle Points: -57
  • Male Posts: 52
  • Member since Dec '14
  • Garage Crawler
updates???
85 x-cab- duals, flatbed, locked, 33's....
70 FJ55-in pieces
ryantowry_81
  • Male Posts: 474
    • Buy me a drink
i want to bump this thread back up so the IFS tech is not lost.
any updates?
i have a t100 i would love to do similar things to
R.DesJardin [OP]
  • Male Posts: 489
I have most of the parts and look at trying to mess with it some more this summer. It's been a crazy past year with the move from WI back to WA. I do want to do this. I have a line on a different front diff which should be stronger and easier to adapt axles to.
« Last Edit: Jul 14, 2015, 02:34:18 PM by R.DesJardin »
R.DesJardin
ryantowry_81
  • Male Posts: 474
    • Buy me a drink
I have most of the parts and look at trying to mess with it some more this summer. It's been a crazy past year with the move from WI back to WI. I do want to do this. I have a line on a different front diff which should be stronger and easier to adapt axles to.
you cant add a statement like that and not share your details!!!!  i hate suspense!
R.DesJardin [OP]
  • Male Posts: 489
Bwaaaaahaaaaahaaaa, hopefully soon I'll know more. My son in law is helping out some so I have more time to design work. So many ideas so little time.
R.DesJardin
ryantowry_81
  • Male Posts: 474
    • Buy me a drink
I hear you there. I have so many plans and dreams but never time to actually build them. I have a t100 I want to do a long travel build on and have owned it for 4 months and it hasn't even moved out of the yard.
Last post May 09, 2004, 06:37:46 PM
by reklund5
Last post Jun 21, 2008, 08:35:03 PM
by Rocks For Brains
Last post Jul 19, 2008, 07:59:52 PM
by KDXSR5
Last post Nov 15, 2010, 06:51:52 PM
by 4wheelingdude
Last post Jul 03, 2011, 05:46:53 PM
by MR.FULL-FORCE
