Author Topic: Rear case oil overfill  (Read 1066 times)
Crunchy Taco
  • Turtle Points: 90
  • Member since Sep '13
  • Flexiest leaf sprung taco I kno
« on: Oct 09, 2013, 07:29:25 AM »
I have way to much oil in my rear case after filling it to spec a month earlier. I'm wondering if this is because my tranny output seal is failing? Anyone ever experience this sort of thing?  I drained the cases back down to their correct level and filled the tranny to its correct level and I'll see what happens. I am just curious if anyone else has experienced this same issue. Any feedback will be greatly appreciated thanks! :driving:
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
Crunchy Taco [OP]
  • Turtle Points: 90
Re: Rear case oil overfill
« Reply #1 on: Oct 09, 2013, 07:32:04 AM »
It seems like even if the trans output seal is failing the oil level would still stay the same all the way through unless more oil gets trapped in one area more than the other.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #2 on: Oct 09, 2013, 05:35:28 PM »
I had the same problem on my 3.0 until Marlin did the mod on my tranny to T-case adapter. This mod is only for the t-case to tranny adapter on the 3.o.
Crunchy Taco [OP]
  • Turtle Points: 90
« Reply #3 on: Oct 10, 2013, 09:30:20 PM »
I'm keepin an eye on it. I have a w56 with duals, no adapter plate. If it keeps happening ill change the trans output seal and c what happens from there. Looks like its guna be one of those trial and error type of deals. Thanks for the reply now I kno Im not crazy and it's happened to someone else
Last post Aug 28, 2005, 10:27:34 PM
by mad squirrel
Last post Jan 02, 2006, 10:14:37 AM
by Rocksurfer
Last post Apr 03, 2006, 08:29:42 PM
by magnajk
Last post Jan 16, 2007, 07:26:54 AM
by 4XFlyin
Last post Dec 26, 2007, 09:33:02 PM
by kneedownnate
