I'm going to have to disagree. I have Bronco with 345k miles that still runs strong and nothing was ever done to the motor.
been there, done that.I got sick of fixing it all the time: radiator, radiator cap, and hoses, water pump, oil pump, timing cover, head gasket, timing chain/gears/guides/tensioner, throttle Cable, e-brake cable. It's my dads problem now.
We need more pics.....also what kind of lift and tires did ya get
the rig looks nice by the way,what future plans do have for it. well good luck
I just need some clarification here.Have you had the Bronco for all of those 345,000 miles
Im just guessing,but does this sound right,The timing chain wore through the guides,causing it to wear into the timing cover causing water to enter the oil,kept driving utill it overheated and blew the headgasket and messing up the waterpump and oil pump and stoping up the radiator and hoses.
Started by Zack1978 New Member Check-In!
Started by toyomaz2000 New Member Check-In!
Started by Rotorwrench New Member Check-In!
Started by trigrate New Member Check-In!
Started by trashyman New Member Check-In!
