Author Topic: brake issue soft pedal  (Read 3198 times)
HOODLUM
  • Turtle Points: 11
  • Male Posts: 81
  • Member since Mar '05
  • Wrecking Crew
    • rightcoast4x4.com
« on: Sep 09, 2013, 12:23:58 PM »
99 Tacoma 2rz.I recently installed a hp D-60 front and D-70 rear axles. I also installed the gm adapter and master cylinder. I bench bled the mc and bled the lines. I even removed the mc to recheck bench bleed and all is good. The issue is the pedal is still way to soft. It goes almost all the way to the floor which is unacceptable. It will stop but not well enough to be safe.I do drive this on the street. I'm out of ideas. Any help is greatly apreciated.
99 TACO 2.7 4CYL  HP d-60 front d-70 rear 5:13's and detroits 63" chevy rear springs second gen rears up front.
http://rightcoast4x4.com/
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: brake issue soft pedal
« Reply #1 on: Sep 09, 2013, 01:12:36 PM »
Re-bleed the whole system. Are the rears disk? Make sure your rotors aren't warped and spreading your pads. Make sure your rear drums are adjusted correctly.
HOODLUM [OP]
  • Turtle Points: 11
  • Male Posts: 81
  • Wrecking Crew
    • rightcoast4x4.com
« Reply #2 on: Sep 09, 2013, 01:25:10 PM »
The front rotors and caliper are just slightly used.I'll def have to check the rear drums. Thank you
downpour11
  • Turtle Points: 142
  • Male Posts: 91
  • Member since Jul '13
    • Slag Factory
    • Buy me a drink
« Reply #3 on: Sep 09, 2013, 01:31:04 PM »
There's air somewhere... might find someone with a vacuum bleeder.  Worked for me.  Gravity bleed at your master cylinder then at your brakes, then vacuum bleed at the brakes, then gravity bleed again.  That's how I got my pedal back.
96 4Runner SAS
HOODLUM [OP]
  • Turtle Points: 11
  • Male Posts: 81
  • Wrecking Crew
    • rightcoast4x4.com
« Reply #4 on: Sep 09, 2013, 03:12:53 PM »
I'll have to look into that as well. Thank you
HOODLUM [OP]
  • Turtle Points: 11
  • Male Posts: 81
  • Wrecking Crew
    • rightcoast4x4.com
« Reply #5 on: Sep 09, 2013, 04:14:09 PM »
I found the issue thanks to Sky's tech line. I got the wrong model 1-ton MC. So back to the parts store to get the rite one. Thanks for the replies guy. :beer:
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #6 on: Sep 09, 2013, 04:27:28 PM »
What were you using?
downpour11
  • Male Posts: 91
    • Slag Factory
    • Buy me a drink
« Reply #7 on: Sep 09, 2013, 09:45:33 PM »
x2 what was wrong with the one you were using?
96 4Runner SAS
HOODLUM [OP]
  • Turtle Points: 11
  • Male Posts: 81
  • Wrecking Crew
    • rightcoast4x4.com
« Reply #8 on: Sep 09, 2013, 10:52:22 PM »
I got a late model instead of the '86 gm that has the 1" bore. The one i got bolted rite up but the pushrod doesn't extend far enough to compress the cylinder correctly.It does work but def. not well enough to be safe.
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #9 on: Sep 10, 2013, 12:53:11 PM »
You went with a 1" bore? Why not use the Toyota 1"? I though the Chevy master was used for its 1.125" bore.
HOODLUM [OP]
  • Turtle Points: 11
  • Male Posts: 81
  • Wrecking Crew
    • rightcoast4x4.com
« Reply #10 on: Sep 10, 2013, 05:27:26 PM »
I only repeated what the guy from sky's tech line said. I wasn't happy with the braking with the 4cyl brake mc I had good pedal but too long of stopping distance. So it makes sense to have a matching brake system to the running gear. I'm sure I could have used the v-6 mc but chose to go with the gm set up.
Last post Jan 14, 2007, 05:47:19 PM
by Yota1
Last post Oct 13, 2012, 10:44:27 AM
by Cheesemaker
Last post Sep 06, 2017, 01:22:08 PM
by THK Matt
Last post May 10, 2018, 06:29:33 AM
by Hopdup
Last post May 30, 2020, 05:12:08 PM
by GreenYoterKrawler
