Author Topic: 22RE to Carb?  (Read 2766 times)
yotacorps81
  • Male Posts: 33
  • Member since Oct '12
  • Livin the dream
22RE to Carb?
« on: Aug 29, 2013, 11:51:27 AM »
Can you use a complete 22RE and make it a carb'd engine essentially making it a 22R?
Life is like a good trail; Rough, dirty, and fun!
toyodaaddict
  • Turtle Points: 399
  • Male Posts: 1,147
  • Member since Sep '08
Re: 22RE to Carb?
« Reply #1 on: Aug 29, 2013, 01:14:55 PM »
yes, but why would you ever want to do that?
Vang530
  • Member since May '12
Re: 22RE to Carb?
« Reply #2 on: Aug 30, 2013, 03:35:06 AM »
this is a step in the wrong direction, even if you do have one laying around its just not worth it
Oroville, CA
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: 22RE to Carb?
« Reply #3 on: Aug 30, 2013, 05:44:20 PM »
You'll need a points distributor too..............
 :cheese:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
yotacorps81 [OP]
  • Male Posts: 33
  • Livin the dream
Re: 22RE to Carb?
« Reply #4 on: Sep 13, 2013, 08:28:58 PM »
My 22R has kicked the bucket after 386,000 miles and I happen to have a 22RE that is in good shape, but none of the wiring or the ECU. Since my truck is my daily driver and I need to get it on the road ASAP, I was trying to find the best way to do that with what I have available.
toyodaaddict
  • Male Posts: 1,147
Re: 22RE to Carb?
« Reply #5 on: Sep 14, 2013, 08:57:59 PM »
Thats reasonable. I cant stand the guys that want to carb there efi trucks because ''its easier''. Go ahead and bolt up the intake, carb, ect. from your 22r onto the re and your good to go. but id suggest holding on to the efi parts and keeping an eye out for the rest of the  parts you need to do the swap. do the research and when the time  is right go efi.
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Re: 22RE to Carb?
« Reply #6 on: Sep 14, 2013, 09:29:55 PM »
What year are the two engines?
There's pre 85 and 85+.    The block and head changed.     If they're both either pre or post you shouldn't have any problems.    One pre and one post might have problems............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
BadnewsBob
  • Turtle Points: 9
  • Male Posts: 350
  • Member since Sep '11
    • Buy me a soda
Re: 22RE to Carb?
« Reply #7 on: Sep 15, 2013, 02:03:07 PM »
I have the complete wiring harness for a 22 RE if your interested. I am in Kentucky. You may not want it now but it would be a good swap for later. I am going for a 3rz so I don't need it anymore.
AE2 USN ret
No matter where ya go..... there ya are.
Hillbilly Offroad
84 xtra cab on 63" chevies and RUF 35" KM2s 22R 5 speed DTC 5.29s Locked front and rear.
merace19
  • Member since Nov '13
Re: 22RE to Carb?
« Reply #8 on: Nov 11, 2013, 02:07:33 PM »
what you ever do with this?
yotacorps81 [OP]
  • Male Posts: 33
  • Livin the dream
Re: 22RE to Carb?
« Reply #9 on: Dec 02, 2013, 04:34:04 PM »
After alot of research, I discovered that I had a post 85 22re and it wouldn't work with my pre 85 22r components. Lucky for me, I had a guy that brought in a 95 Tacoma with a 2RZ that was having compression issues. He wanted a new motor put in instead of rebuilding the one he had. We cut a deal, and I got the old 2RZ off of him for half of the cost of doing the swap for him. I haven't been able to complete the swap into my truck as of yet, but I am currently getting the rest of the parts to finish the swap. Luckily, the motor only needed a set of rings and it was good to go!
Last post May 11, 2004, 06:00:25 PM
by yotapartman
Last post Apr 30, 2005, 02:39:21 PM
by Cheesemaker
Last post Mar 03, 2007, 04:06:19 PM
by Tallchevy
Last post Sep 12, 2007, 07:00:42 PM
by ontherocks
Last post Sep 30, 2010, 08:16:47 AM
by 307rockdog
