Sorry I missed you over the Holiday while you were in town..it would have been great to meet you..
Ohh i like that idea.. im not sure why u would need to do that? Lower ride height maybe??
Correct, low ride height. It is also a better way to accurately gauge your lift, If you use 4" springs and normal drop hangers, you have more like a 6-7" lift. By frenching in every possible bracket then all of your lift comes from your spring.
yeah i kinda like that...still trying to figure out steering...might just go with the hellfire option...just gotta save the cash for that..
are you going to run a fuel pressure regulator?
why?
Never mind.. found a new weber and decided to keep it simple.. when this motor goes ill re think that..
that big gaping hole for the tail light and how it cracks there is one reason I filled in the stock location and used some LED's down in the area below the hatch.
Thanks for sharing your builds!
we are currently building a desert truck as well and would like to here / see more of your other rig.
I was reading about that.. should i? blahhhhh
