Sold
I have an 85 SR5 regular cab pickup, 22RE, 5 speed. Its original paint with a matching camper shell. Absolutely everything works including a/c and heat. It runs and drives good I drive it to work regularly. Interior is very clean with bucket seats, cd player with usb, 4 new speakers. It's a build in progress and I have a lot of parts that I have gathered to finish it. The following are already installed.
Brand new 35" Goodyear mtr's
Trail gear rear bumper
Custom 6 leaf Rears up front spring with stock front shackels
Front shock hoops
Ome 2.5" lift rear springs trail gear 5.5" shackle
10" bilsteins in the rear
U bolt flip kits front and rear
Ifs box with hysteer
Stainless brake lines front and rear
Near new 4cyl 5.29 rear spartan locked third (setup by marlin)
Front is still open 4.10 4cyl
The following are parts i have gathered but not installed.
-Matching 5.29 3rd
-Complete front axle rebuild kit from marlin including backing plate eliminators and weld on brake line tabs
-Extra 21 spline reduction housing and trail gear 21 spline dual case adapter
-Speedo cable extension for dual cases
-Trail gear twin stick kit
-Trail gear long spline slip yoke for the front drive shaft and a extra CV drive shaft from the front of an 83
-1.5" wheel spacers
-2 full face diff armors
-Marlin front axle truss
-I also have some new trail gear leaf spring and shackle bushings for the front leaves. Some other extra misc items too.
In order to make 4wd operable it needs the matching 5.29 3rd installed. If you wanted to install the dual case setup all you would need is a cross member an extra transfercase mount and obviously some driveshaft work.
I will let the whole package go for $6000 obo. If someone were interested in the truck without the extras I would sell it for $5500 obo. (This would include the truck and matching 5.29 third only)
John 7023037806
