well i was under the impression that the speed sensor in the extension housing was still needed for the tcm, but in that case screw it, my truck has a electric speed sensor in the tcase ill just re-use in the gear drive tcase.
Not sure what ur asking its basically 3 wires from the h I just pulled mine out..
Not really sure what your up to? Are you trying to keep the speed sensor for the TCU or are you wanting the speedo to work? These are two different sensors, one is in the trans and the other is in the t-case. I run duals behind an A340f and all I did was bolt on Marlin adapters and buy a speedo extension cable which connected to the rear case just like stock. Marlin sells the adapter to allow electric speedos to work if needed.There is a build thread here and on Pirate.
I am currently gathering parts for the A340F conversion from the A340E in my 2003 Reg cab stepside Pre runner. So far, I am awaiting shipment on the trans minus bell housing and torque converter. I will be adding this: http://www.marlincrawler.com/transfer-case/line-ups/single/gear-drive-left-hand-output-leftyI have the 2.7 motor and my question is, will I need a different flex plate & starter?Thanks.
If the A340F is also from a 2.7 then you should have all you need. I actually used a 3RZ donor trans for the bell housing and flex plate for my swap, I originally had a 22RE trans in my truck that I was swapping the 2RZ into.
Started by Roktoys84 Engine
Started by ksuyota Engine
Started by Sweetkittens Engine
Started by BoG-ToY Transmission/Clutch
Started by Box Rocket Engine
