Aug 15, 2024, 11:29:34 PM
Welcome Guest, Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Store
Calendar
Members
View the memberlist
Search For Members
Login
Register
All
Current Board
Current Topic
Technical Discussion
Project Research and Build-Ups
(Moderators:
Willy Mammoth
Blingn
Topic:
three RZ help?
Pages: [
1
Go Down
Print
Author
Topic: three RZ help? (Read 1875 times)
Capt. Crawler
Rock Master
Turtle Points: 199
Member since Oct '06
three RZ help?
on:
Jun 25, 2013, 05:42:52 PM »
unable to locate 3 RZ wiring diagram for 1998 Toyota 4 runner 4 by 2 engine swap. need to open circuit relay green with orange stripe mine goes to e8 plug everything I find goes green orange 2 E 5 plug?
Last Edit: Feb 01, 2014, 10:51:50 AM by Capt. Crawler
Logged
Capt. Crawler
[OP]
Rock Master
Turtle Points: 199
Re: may be here three RZ help?
Reply #1
on:
Jan 24, 2014, 11:42:47 AM »
Still looking to get out of limp mode?
https://www.youtube.com/user/2june2km?feature=c4-feed-u
Thanx
Logged
Nation
The 1.5K Club
Turtle Points: 1141
Member since Mar '13
@nationallmotors
Reply #2
on:
Jan 24, 2014, 12:11:32 PM »
I know you said you have tested your MAF...In what way did you test it? Or what was the method you used to test?
Logged
Capt. Crawler
[OP]
Rock Master
Turtle Points: 199
Reply #3
on:
Jan 24, 2014, 12:59:55 PM »
My daily driver happens to be a '98 2rz Tacoma so I swapped them out and have been running it everyday since.?
Both are good.
I have no check engine light on at this time?
Logged
Nation
The 1.5K Club
Turtle Points: 1141
@nationallmotors
Reply #4
on:
Jan 24, 2014, 01:06:23 PM »
Got it
Logged
Tungsten Slayer
Rock Master
Turtle Points: 89
Member since Aug '11
Reply #5
on:
Jan 24, 2014, 06:38:06 PM »
I've got some schematics for the 97, but not the 98.... Check to see if you are getting power to the MAF or any of the other sensors. I have had limp mode occur because of one power wire not hooked up.. I had a good friend and wiring guru for the RZ's come and take a look.. 20 minutes later purring like a :chillpill:kat. He said none of my sensors had power and the motor was just in limp... 2500 rpm rev limit and idling rough.
Logged
Nation
likes this
Capt. Crawler
[OP]
Rock Master
Turtle Points: 199
Reply #6
on:
Jan 24, 2014, 08:23:25 PM »
I will check it out. Thanks, so close it's getting frustrating. I was just about to take the wiring out and send it away, but i have the engine running, so I obviously have the EFI relay, fuel pump etc. satisfied.
Last Edit: Jan 25, 2014, 09:08:24 AM by Capt. Crawler
Logged
Nation
The 1.5K Club
Turtle Points: 1141
@nationallmotors
Reply #7
on:
Jan 25, 2014, 09:06:26 AM »
Maybe you are missing a ground?
Logged
Capt. Crawler
[OP]
Rock Master
Turtle Points: 199
Reply #8
on:
Jan 28, 2014, 07:05:56 AM »
Been told that appears in limp mode. So grounds should be OK, although not ruling anything out.
Thanks
Logged
Nation
The 1.5K Club
Turtle Points: 1141
@nationallmotors
Reply #9
on:
Jan 28, 2014, 07:24:31 AM »
Did you check power at the maf sensor? Off of the wiring harness?
Logged
Capt. Crawler
[OP]
Rock Master
Turtle Points: 199
Reply #10
on:
Jan 28, 2014, 09:52:29 PM »
I realized that when I discovered I had my e5 and e8 plugs mismarked Ifforgot to change e6and e7 labels.
So I confirmed wire colors maf to ecu
I never did reconnect batt.
Logged
Pages: [
1
Go Up
Print
(Moderators:
Willy Mammoth
Blingn
Topic:
three RZ help?
