Author Topic: twin cases on an Auto, 88 4RNR  (Read 2485 times)
BirdMan
  • Member since Jun '13
« on: Jun 17, 2013, 02:14:58 PM »
Hey all, just did duals on an auto. Now the issue is what to do about an E-brake?
Can't find an application for Xfer case E-brake, prob have to cut floor to fit anyway.
Looked into line locks, hear good and bad.  Not sure yet.
Also hear Eldorado mod are not so good either.
Running disc conversion from NW Offroad
Input?  Really need to work this out so I can PASS TLCA safety insp.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: twin cases on an Auto, 88 4RNR
« Reply #1 on: Jun 17, 2013, 02:40:27 PM »
What T-cases are you running? If both are gear drive the A-P or Sky brake will work. I did not have to cut the floor when I installed the A-P t-case brake on my 90 ex-cab.
BirdMan [OP]
« Reply #2 on: Jun 17, 2013, 02:48:42 PM »
Running Inchworm because of the Auto.
CCM Runner
  • Turtle Points: -10
  • Male Posts: 243
  • Member since Mar '06
  • brrop!
« Reply #3 on: Jun 19, 2013, 08:25:35 PM »
I have a friend with an 88 runner running duals with the alpro kit and he didn't have to cut his floor
get a bigger hammer!!!!!!!!
BirdMan [OP]
« Reply #4 on: Jun 20, 2013, 07:34:17 AM »
Is your friend running an automatic as well?
OOPS
  • Male Posts: 2,561
« Reply #5 on: Jun 20, 2013, 10:43:08 AM »
Are they both gear drive cases? The A-P and Sky kits both bolt to the gear drive case only.
If you go with a line-lock get a mechanical activated one not an electric activated one.
BirdMan [OP]
« Reply #6 on: Jun 20, 2013, 03:07:27 PM »
Yes, both gear drive cases.  I wonder why every site I have found says for 4cyl gear drive only. No application for V6 or AUTOMATIC?!!!
And would you explain why you say Mech over Elec.
lucky7
  • Turtle Points: 303
  • Male Posts: 778
  • Member since Sep '07
  • CAN'T POLISH A TURD!
« Reply #7 on: Jun 20, 2013, 07:35:11 PM »
Auto granny's are a different length it may not work?
OOPS
  • Male Posts: 2,561
« Reply #8 on: Jun 20, 2013, 08:07:29 PM »
The T-cases you have are 4 cylinder. That is why you have an adapter to hook them up to the tranny.
Electric have to have power to them to stay on all the time. They were designed for drag racing to be used for doing burn-outs and launch off the line on green light. I do not know about the newer ones, but the older ones if the were powered all the time the solenoids would burn out.
OOPS
  • Male Posts: 2,561
« Reply #9 on: Jun 20, 2013, 08:10:16 PM »
Makes no difference, they are mounted on the t-cases.
Last post Jul 02, 2002, 05:24:21 AM
by trt2
Last post May 15, 2005, 03:44:16 PM
by Rocksurfer
Last post May 12, 2009, 03:11:02 PM
by wakkjobb
Last post Feb 20, 2010, 10:56:36 PM
by dan85yota
Last post Dec 16, 2010, 06:03:32 PM
by Sparkplug
