SOLD! SOLD! SOLD!
I am getting out of rockcrawling for a while. With my current schedule I can't get out and use this awesome toy but a few times a year. It's plenty fast to get you to the trailhead, and with the 5:1 Atlas it will creap over just about anything. I usually just leave the transmission in drive so that I can make time between obstacles. It is super stable in off camber situations and climbs like a goat. I never worry about breaking axles or other driveline parts. Plenty of room for two full sized guys, yet narrow enough to avoid damage from most obstacles. I flopped it on it's side one time (fully driver error) and only scratched the paint on the cage.
Asking $22,500. Will consider trades of quality firearms or a Polaris RZR plus cash.
Full custom chassis, 1.75 x .120 wall DOM throughout
20" belly, 107" wheelbase, 3700 lbs
Plate steel belly pan and boatsides
Ford Mustang GT 5.0L...runs great with zero leaks
Ford C6 trans with B&M cooler/fan.
Atlas 5.0 t-case with Poly Performance billet knobs
Ford HP D60 with 5.13's, Detroit, chromos, Longfield Super joints, hi-steer
Warn drive flanges
Full hydro steering with ram behind the axle...big cooler with fan.
GM FF 14B with 5.13's and a Detroit
Fox 16" Coilovers all around
39" BFG Red Label Krawlers
TR beadlocks
Double triangulated 4-links front and rear
GLO diff. covers front and rear
Ron Davis radiator...runs 180-190 even when summer wheeling in 110 degree NV weather
Custom FJ40 fiberglass hood cut down to fit 49" chassis
Makrolon side panels with all dzus tabs
Aluminum roof with all stainless hardware
Neatly laid out and labeled switch and gauge panel
All electrical in fusebox under the dash
Wiring is easily accessible through panel on cowl...5 dzus fasteners holds it down
Warn 9500HS winch with 3/8 synthetic rope.
Artec 6 quart fluid caddy
SWAG Action Packer rack for storage
Custom ice chest rack and included ice chest.
SSV stereo with IPOD hookup, 6x9 Infinity speakers....sounds great
Custom Renegade seats with goggle pocket, sand socks, split harness loops, adjustable sliders, etc.
Crow 5 point harnesses
Art Carr shifter with "reverse mod"
Custom 15 gallon aluminum fuel cell
Hella driving lights.
Hella rocklights
Taillights
Titled and registered in AZ including vin plate
Since I purchased it in October of 2011, I have done the following;
Rebuilt front axle with Longfield Super Joints, new seals, kingpin bushings, Redline gear oil and Lubelocker gasket
Rear axle Redline gear oil with Lubelocker gasket, and Ruff Stuff pinion guard
Installed custom fuel cell with Artec mount
Ice chest rack and ice chest
B&M Transmission cooler with fan
Autometer Phantom 2 5/8" water temp (doubles as tranny temp via a switch), oil pressure and fuel level
Added reservoirs to the Fox shocks, changed spring rates and had valving done by Wayne (ZukIzzy) of Alltech Motorsports
Dual limit straps in front, single in rear
Full engine tuneup and Mobil 1 oil change.
Replaced 8000lb winch with Warn HS9500 and 3/8" synthetic rope.
Installed Infinity Reference 6x9 speakers and built custom mounts for the speaker enclosures. Also installed 30pin IPod connection with charging.
Fire Extinguisher in Quickfist mount.
PRP seat covers
$1200+ in HD driveline work by Adams Driveline.
