Author Topic: picking the right parts  (Read 1663 times)
Countryt2w
  • Member since Jun '02
  • I love Marlin Crawler!
« on: Jun 05, 2002, 05:15:52 PM »
I have a '94 V-6 toy, I'm going to do a 4.3L vortex swap and a straight axle conversion on it. I want to try to stay with Toyota running gear and do a marlin 2Tcase with 4.7:1 gears. What are my best options for a trannie? And will the rear axle be enough or would it be better to go with like a ford 9"?
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: picking the right parts
« Reply #1 on: Jun 06, 2002, 07:15:31 PM »
I am not to keen on what trans to use here.
You say you want to keep Toyota running gear, good man! If you have a 5spd now (R150F), then you are already set. There is an adapter available that will go from the 4.3L to a R series (23-spline output) transmission; I would definately go that route. Then you would be able to adapt eaisly to a gear drive t/case.
If you have resources, and can get a Turbo R151F, then you could save on not needing the adapter to change from a chain drive to gear drive (which you will need if you use your V6 5spd). But the cost of the Turbo tranny will for sure outweigh the cost of the adapter at $349.
Your rear end is plenty strong. Most of the pieces in the 9" drop out are the same sizes/strengths of the Toyota V6 unit if not weaker.
Regards,
Last post Feb 23, 2006, 07:21:05 AM
by toyoder
Last post Feb 22, 2010, 04:36:18 PM
by motorider228
Last post Feb 07, 2011, 07:46:13 PM
by Shamb
Last post Oct 02, 2011, 09:33:03 PM
by brainlessfool
Last post Feb 06, 2012, 09:51:21 AM
by BadnewsBob
