Have a slightly built 86 22 r. It has a header, weber carb,small comp cam and 2.25 exhaust with magnaflow muffler. When I first got it running I set the intial timing to zero per the manual.This sucked, motor just didnt have any power.After fooling around with the carb and getting it tuned right ,I'm now running the timing at 6degrees intial and the motor has more power and seems to run better. Just want to make sure this isnt to much timing. Anybody running about the same setup,what is your timing set at?
