I've pulled and plugged what I believe to be every vacuum line in the engine bay, for no lead on the problem
Have you checked the fuel level in the float bowl after it bucks and dies I had a truck that did something similar and it idled and revved up fine but when I would drive it under higher loads it would buck and die and it ended up being partially plugged fuel lines
Started by YotaYota Engine
Started by Doosty Toyota Pickup/4Runner Tech 1979-95
Started by Toyota cali Newbie Questions
Started by E YOTA Toyota Pickup/4Runner Tech 1979-95
Started by xhootiehoox New Member Check-In!
