Author Topic: New to forum.. looking for advise to build a 2wd 5 lug 8" rear end  (Read 1335 times)
Chris D.
  • Member since Mar '13
Hi everyone.
  I know this is primary a 4x4 rig site, but I know this is the place for Toyota differential stuff.
My name is Chris and I have a boosted Tacoma 2RZ 5 lug and I keep snapping the 7.5's when dead hooked..
So I did a little research and found a nice 1991 G code 8" V6 2wd rear end to build up..
I'd like to find some good used 3.58's and stuff a Detroit Truetrac in it.
I wasn't sure if the Truetrac would hold up to dead hook abuse.    near/around the 300whp area...  (much more soon)
My wife drives the truck once and a while and she's hated the Lockrite in there when going around corners..   lol
Thats why I'm thinking of the Detroit Truetrac for its stock like feel from what I've read/heard.
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
I would use either the tru-trac or maybe a toyota e-locker out of a 4runner or tacoma. The e-locker is selectable so you can have an open diff or a spool depending on what you are doing at the flip of a switch. They come up for sale here and go for $400 to $500.  You should be able to use it in that rear end if it's the same stuff as the 4WD V6 8".  Also get a solid spacer sleeve to replace the crush sleeve between the pinion bearings if you can.
Check out Zuk's site and study it for a while...
http://www.gearinstalls.com/
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
  • I'm not being rude. You're just insignificant.
if you dont mind swapping over... an 8.8 from an explorer is almost a dead swap for these trucks... spring under, 31 spline, and available in limited slip.... not to mention tons of aftermarket support also
Those are some huge welds!
Tillamook, OR
Chris D. [OP]
The 8.8 it a couple of inches wider, I needed a narrower rear end to tuck the wheel/tire combo..
I would have gone this route, but I've owned 3 Explorers and they all had rear end issues and I'm a little bitter..
I'll have some 17x9's out back with some sticky 285 tires..
Then some 15's with drag slicks for track abuse..  I'm thinkin Weld Pro stars..      Always been a fave..
It'll be forward 4-linked within a month or so on QA1 coilovers..
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
oic......   nice looking truck BTW...
Tillamook, OR
Last post Sep 17, 2012, 07:39:48 PM
by Duffil
Last post Jul 06, 2007, 10:01:24 PM
by Plowking
Last post Feb 05, 2008, 02:53:01 PM
by Goose
Last post Feb 02, 2009, 10:03:19 AM
by the_white_shadow
Last post Mar 09, 2016, 02:24:41 PM
by blackdiamond
