I've got a 98 Jeep Grand Cherokee with a 5.9 in it that I'm looking to manual swap at some point. I was thinking of putting in a Terminator AX15 (I'm not sure how well a stock one would hold up), but I need a better OD gear than the .79:1 (my current auto trans has a .69:1 OD, and it could still use a taller gear on the highway, it pulls 7% grades at 1750 rpm doing 60 in top gear no problem).
I've got 3.73s in the axles (which I'd rather not change) and 29.5" tall tires. I'm curious as to what combos are possible while retaining either an AX15 input shaft (or one that I can use with some clutch setup that I can get to work with that engine) and still bolt up to the Jeep t-case (NV242). The .63:1 OD from putting an R150/151 OD gear into an R154 would be awesome, and the 1st gear in the R154 is manageable with the 3.73s. However, being able to retain the 3.83 1st on the AX15 would be nice for towing.
Any suggestions on what combos I should be looking at?
