Being lazy
That's not being lazy, it's a template. Now keep that and use it when your friends want you to build them one too.
Looks good man, I suggest you extend it so it protects the transfer case more. You'd hate to come down on a rock and break a case.
Oh yeah, definitely. I'll be adding a skid coming off the back, as well as the front to hold a mount for the crawl box after I get the frame mounting all done up.
Those are some huge welds!
if i may, i suggest adding another level under your mounts.. so its a flush bottom. just drill the hole bigger so you can set you bolts in them. or use allen heads...
just move the cross member mounts higher up on the inside of the frame rails.
Did anyone happen to get copies of the pictures or dimensions for this?Thanks.
Started by Renaud33 Engine
Started by crawlninspector Toyota Pickup/4Runner Tech 1979-95
Started by rockhound Parts For Sale
Started by helipilot77 Bumpers, Cages, and Tube Benders
Started by locktup Parts For Sale
