Author Topic: Swapping an auto trans out for a 5 speed in 91 4Runner  (Read 4598 times)
dingleberry87
  • Turtle Points: 48
  • Male Posts: 145
  • Member since Jan '08
« on: Dec 19, 2012, 06:21:46 PM »
I'm trying to gather some input for my brother. He currently has an automatic trans in his 4Runner with the 3.0. I myself know a little about our Toyota's but don't know a whole lot like some of you gurus out there. What all is needed to do the swap?
He currently has-
5 speed trans w/ t case
Clutch pedal assy
Clutch slave and master cylinders
Hydraulic clutch line
Cross member
For some reason I wanna say that we'll need manual locking hubs because his currently has auto locking hubs. I'm sure there's a lot more missing and was hoping for some help. Thanks guys
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
the hubs will do nothing really without changing the whole front center axle assembly to a non auto locking section.
otherwise the parts you have listed, sounds like hes got what he needs.
2009 i did this to a 90 4runner with a 91 5spd swap. i went all out and swapped entire body harnesses. what a PITA, you can do it with just looping the park/nuetral switch and splicing the reverse light wire.
Vang530
  • Member since May '12
a bi-metal hole saw (i forget what size i used) and a right angle drill would have helped make things easier (can just use regular one).
having a separate parts truck is much easier and was what i did.
Oroville, CA
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
Having a parts vehicle made a world of difference. And yes a drill for the clutch master on the firewall
Sent from the HO KID network using Tapatalk 2
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
Don't forget the flywheel.
UndefinedTaco
  • Turtle Points: -4
  • Member since Aug '11
  • Built by trial and mostly error
R150f
New clutch
Clutch pedal
Slave cyl
Master cyl
5 speed crossmember
5 speed driveshaft
83' Pickup "ShitBox" - more parts
92' Pickup "Doomed" - some parts
dingleberry87 [OP]
  • Turtle Points: 48
  • Male Posts: 145
Sweet thanks guys. I think I'll be starting that project for him this weekend. Wish me luck lol
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
no problem. chime in, if you need help or have questions.
dingleberry87 [OP]
  • Turtle Points: 48
  • Male Posts: 145
Thanks. Will do
Cyberman
  • Member since Dec '07
    • Build Thread
You probably already have the clutch switch.  Another bonus would be the clutch start cancel switch, for starting on hills and such.
Sent from my DROID RAZR using Tapatalk 2
'91 Xtra cab 3.0 SAS, 5.29s, single 4.7 transfer, locked f/r, 35s
My Frame-up Rebuild Thread
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
that requires more wiring lol or swapping of the whole harness.
dingleberry87 [OP]
  • Turtle Points: 48
  • Male Posts: 145
UPDATE: before pulling trans, we did a compression test just for the heck of it and found cylinder #6 was dead :(
So now we gotta do an engine n trans project lol
Cyberman
    • Build Thread
Ouch  :-\
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
may as well do a 3.4 swap while you're at it.
Cyberman
    • Build Thread
X2
I replaced mine with another 3.slow,  but when this one goes it'll have a 3.4.
Last post Feb 15, 2004, 07:55:39 PM
by Marlin
Last post Nov 04, 2004, 12:01:43 AM
by iNfErNaL
Last post Oct 19, 2004, 08:30:36 PM
by Rollover Roy
Last post Jun 17, 2009, 09:40:04 PM
by lucky7
Last post Feb 24, 2009, 06:44:02 AM
by 91xcab
