Author Topic: 33s on the 60  (Read 3802 times)
mtb fam
  • Member since Aug '12
33s on the 60
« on: Dec 17, 2012, 03:15:38 PM »
currently have 30x9.50 o stock 15s.
the plan is to bump up to a 33x10.50 we also will be going to a 15x8 wheel.
im looking into the goodyear wrangler mtr,bfgoodrich km2s and the cooper mtrs
i have looked online and it seems that what i would like to do will work with no lift if any one has 33s on a stock fj60 will itwork? and another thought is to do a small lift no bodylifts.  any help on a cheaper 0-4  inch lift would be a lot of help. thanks
daniresch
  • Turtle Points: 930
  • Male Posts: 761
  • Member since Apr '11
Re: 33s on the 60
« Reply #1 on: Dec 17, 2012, 07:38:08 PM »
 i can't help you on the lift, but you'll love the cooper stt mtrs if you choose those :thumbs:
mtb fam [OP]
Re: 33s on the 60
« Reply #2 on: Jan 01, 2013, 08:42:51 PM »
i have coopers on my jeep and have so much fun going to and from work in the snow with them. money well spent! :)
FJ40NUT
  • Member since Dec '14
  • Toyotas are the coolest
Re: 33s on the 60
« Reply #3 on: May 10, 2015, 08:36:42 AM »
I've run 33's for many years with Old Man Emu heavy lift and 4.11 or 4.56 gearing.  Great combo.
Did Toyota accept a government bail out?
cruiserpilot
  • Turtle Points: 53
  • Member since Apr '15
Re: 33s on the 60
« Reply #4 on: May 12, 2015, 11:41:38 AM »
You can run 33's on a 60 with a 15x8 rim.  Make sure, minimum 3.5" BS.  If you can, see if you can fit a rim to
the front before you buy.  TRE and caliper clearance are the issue.  For minimal lift,  I can only recommend OME.
I've been running them for years and they are the best.  If you can find new stock height leafs, it will probably give
you 2" of lift, just getting back what has sagged away.
Burl
  • Turtle Points: 271
  • Male Posts: 389
  • Member since Jan '07
  • Wannabe Smokejumper
Re: 33s on the 60
« Reply #5 on: May 22, 2015, 07:36:29 AM »
I have 305/70/16 goodyear duratracs.  Really good tires.  I have the short add leafs front and rear from man a fre, and the CCOT 1" shackles.  The tires rub a bit when there's a lot of weight on the 60.
Burl
  • Male Posts: 389
Re: 33s on the 60
« Reply #6 on: May 22, 2015, 07:38:09 AM »
Oh ya stock gearing currently and it blows.  I have a set of 94 FZJ80 axles though that are ready for the swap.
