Author Topic: Banjo fitting on a mini truck axle.  (Read 2166 times)
locked 4x4
  • Male Posts: 466
  • Member since Aug '09
« on: Dec 12, 2012, 09:19:42 PM »
Just wondering if anyone has run banjo fitting on a mini truck axle.  Seems like a good solution to get rid of the little piece of line that most people run between the brake line and the caliper.  Make everything a little more simple.  My worry is that where the fitting that goes into the caliper is not machined but I don't see what that couldn't be smoothed out somehow to make a tight fitting.  If anyone has done it or has an idea let me know.
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #1 on: Dec 12, 2012, 10:23:28 PM »
That is a pretty good idea, especially when the backing plate is removed as there is no structure to hold the hard lines. But I think the issue is the threads at the caliper are designed for a tapered brake line ferrel and I don't think there are enough of them to accommodate a banjo style bolt.
It's certainly worth investigating. :thumbs:
Sent via Tapatalk + Jailbroken iPhone4
Dirt Mover
  • Turtle Points: 186
  • Male Posts: 355
  • Member since Sep '03
  • Chrome won't get you home
Re: Banjo fitting on a mini truck axle.
« Reply #2 on: Dec 13, 2012, 05:20:37 PM »
I think the 4Runners with the 3.4s have that set up and they are used with the Taco brake upgrade. I could be wrong.
Phazertwo
  • Turtle Points: 8
  • Male Posts: 812
  • Member since Aug '05
« Reply #3 on: Dec 15, 2012, 06:34:03 AM »
Look at the FROR taco brakes set up.  Lets you use a taco caliper, with the banjo fitting, and it allows you to pull the hub/spindle as one unit which means faster axle tear down.  I have all the parts for this sitting on my work bench, just waiting for a little free time!
PZ
TRACKER
  • Turtle Points: 4
  • Male Posts: 442
  • Member since Sep '06
« Reply #4 on: Dec 15, 2012, 08:45:35 PM »
3.4 caliper will not bolt on the mini knuckle .
Pride - is what drive a man to do his very best even when no one is looking ..
locked 4x4 [OP]
  • Male Posts: 466
« Reply #5 on: Dec 17, 2012, 12:02:51 PM »
I don't believe the the threads are tapered on the brake caliper.
locked 4x4 [OP]
  • Male Posts: 466
« Reply #6 on: Feb 18, 2013, 06:19:42 PM »
Well I know its been a while but banjo fittings do work on mini truck calipers.  Been running them for a couple months with no issues.  I had these made up at a transmission shop that did brake lines.  I actually did a soft line all the way back to the master brake cylinder.
Last post Feb 06, 2003, 07:57:33 PM
by cruzila
Last post Jun 29, 2006, 08:58:22 PM
by 95Toyota
Last post Apr 03, 2007, 04:39:46 PM
by moto
Last post May 22, 2009, 11:29:15 PM
by Hammerhead
Last post Dec 29, 2009, 05:38:37 PM
by 1990GT50
