... a very plugged radiator....
As we all know, overheating a 22 can be mean a head job at the very least. Overheating it few just a few seconds can warp an alloy head or blow a head gasket.Coolant maintenance, like oil changes, should be done. You can buy coolant testers real cheap to check the effectiveness. But changing and flushing your system every 20,000 or will go along ways to prevent an overheating problem. T-stats are inexpensive and easy to replace.A 50/50 mix with DISTILLED water is recommended. Ethylene Glycol has rust inhibitors and also acts as a lubricant, so running pure water can toast a water pump very quickly. It also raises the boiling of point of the mixture. You can run up to 70/30 (70% coolant) if running in extreme cold weather. Running pure ethylene glycol goes the other direction and lowers the boiling point and will raise the freeze temperature…. No bueno.With the price increases in auto parts, the $150 NAPA copper radiator I bought about 17 years ago, now is about $300+, so obviously it pays to preserve your vehicle with diligent maintenance. Gnarls.
Started by saf85 Parts For Sale
Started by pickeledpigsfeet Rigs For Sale
Started by CruzrDave Parts For Sale
Started by NCK4L Rigs For Sale
Started by blumagoo Parts For Sale
