Author Topic: 22re Will not idle read my log on whats been done.  (Read 4807 times)
tgmaul88
  • Turtle Points: 30
  • Male Posts: 985
  • Member since Feb '12
  • Im still alive
« on: Nov 23, 2012, 12:02:22 PM »
Ok i need the 22re gods to work with me on this,
so just got done with a complete rebuild  bored decked milled yada yada, anyways i get the motor in the truck, hooked everything up  filled it with oil first
it started and idled fine. i didnt let it warm up. today i went out and installed the radiator and. i started the truck on its own idle.   letting it warm up  as im dumping in fresh coolant
its been running now for 2 min on its own idle.  once it gets warmer, not super hot but warmer  while idling it just out of the blue dies. i can restart it but only with my foot on the pedal. im letting it cool down right now to see if will idle when cold,
any ideas please im stumped
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
its a 22re from a 1985 truck ran perfect before overhaul
Royota
  • Male Posts: 127
  • Member since Aug '12
  • Pacific Northwest 4x4
Clogged fuel filter or bad sending unit? Have you been able to re-create this situation? What kind of "dieing" does it do? Sputter and cough or is it like the engine siezes from a bad rebuild? That's interesting... see if you can gather as much specific information as possible. I'd start by replacing the fuel filter though that's just simple and takes 20 minutes to eliminate one possible cause.
May Bobby Long be forever immortalized in his work and deeds to the Toyota 4x4 community. Because of a select few including this wonderful man, none of us have to drive Jeeps. He will be missed.
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
Brand new oem toyota fuel filter  i drained all the old gas out of the tank and put 3 or 4 gallons in the tank.,    i can start it still, and it will run strong at like 2500 and up but anything under 1000rmp it dies   i can restart it with my foot on the gas pedal
EGR is there could this be a cause? the pipe that goes to the diaphram was very hot.
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
once cold truck starts again runs for a little while then shuts off
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
Coolant temp sensor bad or unplugged. Afm bad or unplugged. tps also has to do with idle, as does the 02 sensor.
I just went through all of this on mine and it turned out to be vac leaks, but it wouldnt hold idle at all.
Have you checked it for codes yet?
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
no light
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
so i looked at this http://i230.photobucket.com/albums/ee218/KDXSR5/Hoses%20and%20such%20for%20Sweet%20Jane/HosesandwiresandsuchforSweetJane001.jpg
AND SEEN  that my hose were not correct, so i swapped them and truck runs fine for now,  didnt let it warm up, but the hoses could have been the fault, ill keep you posted
UndefinedTaco
  • Turtle Points: -4
  • Member since Aug '11
  • Built by trial and mostly error
Idle air control, big big possible chance..especially on early RE's (85-89)
83' Pickup "ShitBox" - more parts
92' Pickup "Doomed" - some parts
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Fuel may not be getting to the injectors due to clogged fuel tank vent lines or low fuel pressure. Do you smell fuel? Since the fuel system is closed if you smell fuel under the hood check the charcoal canister and make sure it is not bad. Also make sure the hoses to the canister are properly installed and not pushing fuel through it and into the intake.
tgmaul88 [OP]
  • Turtle Points: 30
  • Male Posts: 985
  • Im still alive
i do not smell fuel,   the truck was running for only 2 min, i felt the egr pipe to manifold and it was very very hot. like it was feeding mass amounts of exhaust into the intake, ive got fuel.  it will start and run great cold, once the temp gets up it kicks in whatever it is and kills it
Last post Apr 15, 2005, 09:33:28 AM
by DeMented Toys
Last post Jun 13, 2010, 09:38:48 PM
by Mega Baby Huey
Last post Jan 25, 2007, 03:05:53 PM
by runyotarun
Last post Mar 07, 2009, 12:26:39 PM
by RABIDYOTA
Last post Oct 24, 2022, 02:06:52 PM
by OVRAROK
