When I do stuff like that, I like to use the weld seam as my reference for the notches. So I can make sure each one is in plane. Also, lets see I need a piece of tube with a a notch 90 degrees or inline with the first one, Ill make sure the notcher is level and straight up and down, clamp the tube in the notcher like you are going to cut, home some tube in the first notch, and put a level on it, so you know if its in plane
