Author Topic: 3.0 v6 power upgrades  (Read 9640 times)
codydeluca93
  • Male Posts: 19
  • Member since Aug '12
« on: Aug 15, 2012, 03:46:22 PM »
i have a 1993 Toyota 4 runner with a 3.0 v6 that is a dog........ is there any cheep upgrades to throw on that will help?
bigarms23
  • Turtle Points: 111
  • Male Posts: 2,897
  • Member since Jun '07
Re: 3.0 v6 power upgrades
« Reply #1 on: Aug 15, 2012, 06:04:38 PM »
you can do a free flow exhaust system but i would swap in a 3.4 for more power
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #2 on: Aug 15, 2012, 09:20:11 PM »
Nature of the beast, dog and gas hog, live with it or go 3.4!!!!!!!
T.Rex
  • Male Posts: 164
  • Member since Mar '10
« Reply #3 on: Aug 15, 2012, 10:53:35 PM »
Electric fan
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #4 on: Aug 15, 2012, 10:54:14 PM »
It's called a 3.flow, not 3.slow :thumbs:
Is this an auto or 5-speed? How many miles are on the motor?
One of the best things to do for a tired motor, however costly, is to get a fresh valve job done. That will brighten it up a lot and you'll see much improved MPG, easier to start, smoother idle, better bottom end power, minimized run-off during shut down, and have an easier time passing smog (if this applies to you).
It just depends how wore out the engine is. A quick compression test will yield the needed answers to this question.
Also, with a fresh top end you'll have a solid platform to start throwing aftermarket parts at and the motor will realize more gains from said parts too :thumbs:
After I blew the head gasket on my ~200k 3RZ-FE 4-cylinder (long story), I had a valve job done before slapping the head back on and WOW what a difference! It was a night and day difference, seriously, but this was because unbeknownst to me it really needed it. Starts easier, purrs like a kitten, is also more stable at near stall conditions during Rock Crawling too. It made a huge overall improvement for me.
Of course you've got two heads so the cost is higher (I highly recommend Genuine Toyota head gaskets!), but if you are serious about this, then I'd start with a fresh top end (it's short and less expensive than a full rebuild anyhow) and then work my way up!
:twocents:
Sent from my iPhone connected to the BigMike Network using Tapatalk
codydeluca93 [OP]
  • Male Posts: 19
« Reply #5 on: Aug 16, 2012, 12:45:37 PM »
cool thanks it is an auto and about 130K compering it to my 22RE crazy but have to make due. ill try the fan trick.
  • Administrator
  • 511:1 Club
« Reply #6 on: Aug 16, 2012, 12:59:11 PM »
Electric fan is a great idea. I _HIGHLY_ recommend using a Delta Current Control controller for this: http://www.dccontrol.com/constant_temperature_controllers.htm
The motor has only 130,000 miles and it's tired? Who owned the truck before you, Enterprise Rent-A-Car?? :ack: :ack:
Seeing how it's an automatic, I'll leave it at this: It's always gonna feel sluggish until you change to a more powerful engine. You may not like this, but I'd recommend one of the following: 1) Sell and replace it with a 5-speed version, or 2) Do an engine conversion to a 3.4-liter 5VZ-FE. Short of these two options, if you are already dissatisfied with its performance combined with its handicap (auto), I don't think you'll ever feel satisfied.
If you or any other automatic owner is thinking about doing a manual transmission conversion, I advise against this. Do it the proper way by finding a factory equipped 5-speed truck.
Last post Oct 05, 2004, 01:02:15 AM
by BigMike
Last post Apr 08, 2012, 02:50:54 PM
by jta
Last post Jul 29, 2006, 09:56:21 AM
by toy85ota
Last post Jan 26, 2007, 01:57:47 PM
by snowplow
Last post Oct 05, 2016, 03:44:00 PM
by Smithk2ski
