Author Topic: my runner seems to high  (Read 8336 times)
greenjacob
  • Member since May '08
« on: May 29, 2012, 08:36:03 PM »
just got a 86  4runner is sas with rufs up front and 63 in the back with a 2inch block on 39.5s
29inch from ground to the frame at the cross member what are some of your rigs?
1986 4runner 93 22re 5.29s locked f/r duals twin sticks 39.5s
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Member since Aug '10
  • Get Some
Re: my runner seems to high
« Reply #1 on: May 29, 2012, 08:46:38 PM »
  :worthless:
greenjacob [OP]
« Reply #2 on: May 29, 2012, 08:49:42 PM »
heres only pic i got from last weekend at browns camp
santa cruz crawler
  • Turtle Points: -7
  • Male Posts: 682
  • Get Some
« Reply #3 on: May 29, 2012, 08:51:13 PM »
Looks good ! Nice runner !
greenjacob [OP]
« Reply #4 on: May 29, 2012, 08:54:05 PM »
im oredering new 36 iroks and wanting to know how tall some other toyota are with a sas and 5inch springs.
see how many leafs i got drop out my pack to get not normal leavles or maybe i just think mine extra tall? havnt had a toy in a few months
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
  • Member since Sep '10
    • Buy me a cigar
« Reply #5 on: May 29, 2012, 11:00:31 PM »
That doesn't seem to tall. My 3rd gen Sased with 35s is 26-27 to the bottom of the front crossmember with 6" up travel, I had it at 24 but I like up travel. The only reason I have that much up travel is because I notches a bunch out of my frame for tie rod and drag link clearance.
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Member since Sep '04
  • Colorado Rocks!
    • http://www.rockfrogs.org
« Reply #6 on: May 30, 2012, 10:19:33 AM »
My 4Runner
Frame height on 39.5" tires at 8psi is 26".
RUF/TG springs in the front
4" TG rear springs
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #7 on: May 30, 2012, 10:24:42 AM »
Maybe to under the cab. No way it's 26 to front spring hanger.
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
« Reply #8 on: May 30, 2012, 03:03:32 PM »
Measured from the ground to the bottom of the frame right at the t-case crossmember.  I don't know of anybody that measured the front crossmember height.  Ground to frame is an equal way to measure.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
« Reply #9 on: May 30, 2012, 04:32:18 PM »
Hmmm, always had people measure to the front crossmember. Mine must be like 22-23 with that way of measuring.
greenjacob [OP]
« Reply #10 on: May 30, 2012, 05:23:20 PM »
ya that what i was looking for. ok thanks 3 or 4 inches lower was what i was thinking.
greenjacob [OP]
« Reply #11 on: May 30, 2012, 05:24:05 PM »
thanks volcom.
gona order 36 iroks and try and lower it 3inchs here soon
85runner_
  • Turtle Points: 2
  • Male Posts: 204
  • Member since Dec '07
« Reply #12 on: May 30, 2012, 05:39:02 PM »
39.5" irocks
Frame 26"
Skid 25"
b*std toys up front 63s 1/2 ton with over load cut down for the rear. 2" blocks.
Top of cage 72 1/2"
Diff clearance 12 1/4"
greenjacob [OP]
« Reply #13 on: May 30, 2012, 07:05:54 PM »
63s 1/2 ton with over load cut down for the rear. 2" blocks is what i got and im 3 inchs taller thats the part i dont get
greenjacob [OP]
« Reply #14 on: May 30, 2012, 08:40:22 PM »
8 8.5 inchs from top of my front spring pack to the bottom of the fram
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
« Reply #15 on: May 31, 2012, 07:55:13 AM »
I could french my front spring hanger up a couple inches and it would throw that measurement out the window. Or different models of Toyota's (1st gen 4Runner vs 3rd gen 4Runner) have completely different frame builds.
Ground to frame at the crossmember is a true measurement of height.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
greenjacob [OP]
« Reply #16 on: May 31, 2012, 06:34:57 PM »
can anyone point me to a nother post about this? i cant find one
greenjacob [OP]
« Reply #17 on: Jun 03, 2012, 08:27:16 AM »
went to 4wheel parts was gona get 36iroks they look small. haha i couldnt do it gona get new 39.5 iroks
zembalayan
  • Turtle Points: 254
  • Male Posts: 486
  • Member since Feb '08
« Reply #18 on: Jun 03, 2012, 03:58:14 PM »
Check out this thread:
http://www.pirate4x4.com/forum/showthread.php?t=599542
You have the IFS frame so you'll be fighting more than the SA and 2WD model owners to lower your ride height and keep your up travel.  Most of the online measurements of ride height seem suspect, and ultimately who cares how it looks as long as your suspension works.
Here's mine.
37s with Marlin 4" springs with lower most leaf removed and deep frenching into an 80 series front axle so that the springs fit inside the top of the axle housing rather than way high above on overly tall spring perches.
No measurements to share right now since the truck's still in progress.
« Last Edit: Jun 03, 2012, 04:49:39 PM by zembalayan »
zembalayan
  • Male Posts: 486
« Reply #19 on: Jun 03, 2012, 04:22:29 PM »
Here's some more in progress shots of how my truck lost a bit of height.
When my Marlin Crawler 4"ers wear out, I might be thinking of some custom reverse eye leaves to drop down a bit more but keep the up travel with same arch.  For better or worse, I am keeping the stock tie rod position of the 80 series steering set up, but the passenger side frame may still need to be notched for drag link clearance with my double sheered passenger side only Slee Hi-steer arm.  (BillyBob13's arms look badass, and maybe something for the future.)
Here's a pic from the back.  Let some more trimming begin.
« Last Edit: Jun 03, 2012, 04:45:24 PM by zembalayan »
pumkin toy
  • Turtle Points: -4
  • Male Posts: 3,561
  • Member since Sep '05
  • Do You Know A Sweeney Bro?
« Reply #20 on: Jun 03, 2012, 07:30:53 PM »
the frenched 80 series housing is badass!  I really like clean inventive mods like that
97 4runner Limited
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #21 on: Jun 03, 2012, 08:23:01 PM »
sickest toy housing ive seen!
Could that be done on a Hilux housing?
zembalayan
  • Male Posts: 486
« Reply #22 on: Jun 03, 2012, 08:50:40 PM »
Thanks, Pumpkin Toy!  I like it a lot, too, but before anyone makes any erroneous assumptions about whose handiwork this is, the following "before" axle housing picture is all I could accomplish with my angle grinder:
Whoopdeedoo, right?  Then I handed it off to Daryl Dickerson and Bink Hurrey at Bink's Fabrication in Salida, California, who took my request for the fabrication of as low as possible spring perches to a whole new level, which is what you see in the "after" pics in my original post above.
zembalayan
  • Male Posts: 486
« Reply #23 on: Jun 03, 2012, 09:01:16 PM »
100% it could be done.  One thing about the 55" mini truck housings is the super high stock perch location next to the diff on the passenger side.  It may have been designed in such away for a very good reason, especially for a mass produced stamped housing.  I don't know.  They are cheap and common enough to take a swing at it.
On my 80 housing in the original post above, some machined reinforcement pieces were made to strengthen the frenched perch.  We will see how it goes.
Advantages include less axle wrap and a more tucked up underneath, FROMBE tierod that comes with stock 80s.
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
« Reply #24 on: Jun 03, 2012, 09:10:35 PM »
Badass. I've tossed around the idea of doing this to my tg front housing but I'd probably trash it.
zembalayan
  • Male Posts: 486
« Reply #25 on: Jun 03, 2012, 09:24:43 PM »
I think this type of mod would be easier with a Ruff Stuff, Diamond, or a TG housing as long as your diff webbing was centered enough so that only cutting into the tubing, not the webbing, would be necessary.  My rear axle housing is a Ruff Stuff centered 9.5" Toyota full float LC housing, and the rear perches aren't frenched, but they are low-profile enough to put the springs only a .25" above the axle tubing.  In the front, frenching a custom housing might help for leaf spring guys.  Mind you, I am rolling a trail rig here, no racer, so full gussetting and total housing strength is not so much of an issue for me.  I want balance and reliability.  Still skeptical of my ability to run/tune COs and optimizing link geometry on a trail rig that will see highly variable load weights and on and Offroad conditions.  BUT I admire the guys who can and do run rigs that work well with COs.
« Last Edit: Jun 03, 2012, 09:33:48 PM by zembalayan »
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #26 on: Jun 04, 2012, 10:07:45 AM »
that will definitely be a mod for the future!!! Do you have a build thread?!
greenjacob [OP]
« Reply #27 on: Jun 04, 2012, 06:20:36 PM »
badass!
Yopar
« Reply #28 on: Jun 04, 2012, 07:04:35 PM »
Those perches are the one of the coolest mods I have seen.
No need for U bolts either!
--'87 4runner ifs rig, locked f/r, 4.88/33, dual cases 2.28/4.7 marlins
--'83 long bed, bobbed, aussie locked f/r, 4.10/33, dual cases 2.28/4.7 marlins
zembalayan
  • Male Posts: 486
« Reply #29 on: Jun 05, 2012, 03:07:10 AM »
No build thread, but I may post up some before and afters while consolidating some of the pics, and past posts, and stuff I really like about my Runner in a new thread in the rig gallery soon once I get her back and have shaken her newest form down this season on the trails:
Here is a link to some earlier fab and cage work done by Dan Trout of Fishmouth Fabworks on his FB page:
https://m.facebook.com/media/set/?set=a.157589460951952.30438.145336198843945&type=1&v&refid=9
Here is a link to some of the latest from Binksfab's FB page:
http://m.facebook.com/media/set/?set=a.396433137048552.97739.152674484757753&type=1&v
And last but not least, I'm super proud to be running a bunch of Marlin Crawler parts on this truck so I got get some pics of that gear to post up, too.
The truck is pretty basic (and gutless with her 22RE), but I am hoping with the added beef in the axle department, the added width, and the lower ride height, she'll be much more stable and continue to be just as reliable as she's been for me on the trails.
Last post Dec 22, 2003, 12:02:46 PM
by hawaiian
Last post Apr 18, 2008, 09:39:09 AM
by BigBs84
Last post Dec 25, 2009, 09:45:14 PM
by 86bobbedtoy
Last post Mar 01, 2011, 02:55:56 PM
by racerx233
Last post May 18, 2011, 12:27:08 AM
by Yota Rolla
