Author Topic: Long leaf conversion Q's???  (Read 4146 times)
spanky
« on: Jul 13, 2002, 08:25:23 AM »
I want to swap in longer leaves for that sick travel we all desire! There seems to be so many ways to go. A few of my buddies have gone with Toy rears up front and S-10 rears out back. One guy I know has S-10's in the front and f-150 rears! Another has Suburban springs in the back. Currently, I'm running 3" Downey's in the front and 2" Ranchos in the back, both with 3" longer shackles. From what I understand, if I use the rears up front, I'll have to weld new fixed mount about 2" farther up front to make up for added length. This is where I get concerned. What are the suspension height changes? Will the 2" Ranchos lift the same as the 3" Downey's in this configuration? Do you remove any leaves (loads not the same)? If the S-10 springs are 7 or 8 inches longer do I just weld the new mounts 7" up or what? Do i just locate the axle where I want and re-do both ends? What about shackle angle? Do I make super long shackles? If I compress the spring to full flat length, how should the shackle be sitting (flat against the frame or at what angle)?
What have you guys done out there? Any help would be appreciated.
P.S. What suspension layout is in that Orange Toy climbing that white jeep in the random photos on the Home page??!!!
Thanks
Spanky
« Last Edit: Dec 31, 1969, 04:00:07 PM by -1 »
scaler de piedra
AZROCKER7
  • Member since Jun '02
  • AZCRAWLER
Re: Long leaf conversion Q's???
« Reply #1 on: Jul 16, 2002, 03:27:47 AM »
Hey Spankey 8) one way you can go is to use allpro rear springs the 56" and use factory toyata front spring mounts r/s 48414-35120 and L/S 48415-35050.these mounts are from the 89-95 trucks. these would move 6" forward from the stock location then move your rear shackle hanger back 3".this is the way i'am doing my rear setup. hope this helps you out some 8).
« Last Edit: Dec 31, 1969, 04:00:00 PM by 1056988800 »
1988  PICKUP 22RE 5 SPD. ALLPRO SAS MARLIN MC08 L.C. ENG.CAM,HEADER. DETROIT LOCKERS F/R. V6 THIRD 5:29'S, FROR TWIN STICK,35" BFG MUD T/A'S, WARN XD9500I WINCH.........WHEN IN DOUBT GAS IT!!!!
AZROCKER7
  • AZCRAWLER
« Reply #2 on: Jul 16, 2002, 03:28:38 AM »
Hey Spankey 8) one way you can go is to use allpro rear springs the 56" and use factory toyota front spring mounts r/s 48414-35120 and L/S 48415-35050.these mounts are from the 89-95 trucks. these would move 6" forward from the stock location then move your rear shackle hanger back 3".this is the way i'am doing my rear setup. hope this helps you out some 8).
hawaii500_1999
  • Turtle Points: -7
  • Watch this!!!!!
« Reply #3 on: Jul 16, 2002, 03:50:18 AM »
i'm really interested in this.  i also have been flooded with different ways of setting up sus.  i think most folks work with what they have.
what i have is chevy full size springs that i am going to put in the rear of my rig some day and...............
i was wandering about the shackle angle too.   :confused:
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
rEdnECkwHeE1eR
  • Turtle Points: -68
  • Male Posts: 1,430
  • Still tipin'
« Reply #4 on: Jul 16, 2002, 10:17:12 AM »
have any of you guys heard of late model (94) ford ranger springs ??? ???
Liquor up front
Poker in the rear
AZROCKER7
  • AZCRAWLER
« Reply #5 on: Jul 17, 2002, 03:43:06 AM »
::) I WORK AT A FORD DEALER SELLING PARTS AND HAVE NOT HAD ANYBODY ASK FOR THOSE SPRINGS,THE ONLY THING WE SELL FOR TOYOTAS IS THE FORD FRONT SHOCK MOUNTS{87-89 F2504X4 E5TZ-18183-A}. I USED FORD U BOLTS, SPRING PLATES AND MODIFIED SUPER DUTY REAR SHOCK MOUNTS FOR MY REAR SETUP.IF YOU WANT PART #'S LET ME KNOW 8)
                     TAKE CARE ;D
Brandon
  • Hawk
  • Turtle Points: 193
  • I believe in Life before Death
    • www.RiverCityRockCrawlers.com
« Reply #6 on: Jul 17, 2002, 05:54:18 AM »
ford f150 springs are the ticket now, with the offset the departure and approach angles are good and they are long and soft..
Of course new mounts are needed..
btw - yj's and my angle..
Brandon Miller
RCRC, Sacramento, CA
spanky [OP]
« Reply #7 on: Jul 18, 2002, 03:04:13 AM »
Hey Brandon,
F150's in the rear or front also?
Spanky
scaler de piedra
Brandon
  • Hawk
« Reply #8 on: Jul 18, 2002, 03:11:01 AM »
some people run em front n rear. I run 44044's up front, mazda hybrid pack in the rear.
with the mazda you just have a mount welded right in front of the stock one and bolt em on.
In my jeep with yota axles I run YJ springs front and rear
Brandon Miller
rEdnECkwHeE1eR
  • Male Posts: 1,430
  • Still tipin'
« Reply #9 on: Jul 19, 2002, 09:50:53 AM »
I know of a late model ranger laying i a buddys yard thats rolled Im not sure if the springs are there or not I hope so  :nerv: just wondering the length and flex of the springs mabe I should go check them out :shake: :shake: :shake:
Liquor up front
Poker in the rear
rEdnECkwHeE1eR
  • Male Posts: 1,430
  • Still tipin'
« Reply #10 on: Jul 24, 2002, 11:11:52 AM »
what year f150 and how much lift do they give?
I am torn be tween F150s and 88-98 Chevy 1/2 tons
Could I get the chevys and drill a new pin hole for off set?
Liquor up front
Poker in the rear
rEdnECkwHeE1eR
  • Male Posts: 1,430
  • Still tipin'
« Reply #11 on: Jul 25, 2002, 06:11:16 PM »
Brandon?
Any one?
Liquor up front
Poker in the rear
spanky [OP]
« Reply #12 on: Jul 26, 2002, 03:30:56 AM »
I'm very interested in the answer too, rEd!!!
scaler de piedra
rEdnECkwHeE1eR
  • Male Posts: 1,430
  • Still tipin'
« Reply #13 on: Jul 26, 2002, 04:53:05 AM »
Yeah I think there all focused on the MCR I wish I could go :'( :'( :'( :'( :'(
Liquor up front
Poker in the rear
Last post Mar 01, 2007, 04:36:45 PM
by unclejpl4x4
Last post Sep 09, 2007, 11:00:42 PM
by THK Matt
Last post Feb 22, 2008, 09:11:31 PM
by 46&2
Last post Feb 17, 2011, 11:58:36 AM
by 953rz4runner
Last post Dec 31, 2014, 08:33:22 AM
by mtnmalr
