Author Topic: 87 4runner brake issue  (Read 2211 times)
874runnertoys
  • Member since Oct '10
« on: Apr 02, 2012, 06:25:10 AM »
OK i just did a rear disc brake kit on my 4runner and also a 1' bore master cylinder ,v6 booster and installed a e-line lock .
checked all lines ,bleed the master cylinder ,bleed the system three times ,checked all fitting and there still no braking pedal goes down the floor  :headscratch: .
Any idle what it mite be anyone :dunno:
« Last Edit: Apr 02, 2012, 07:41:26 AM by 874runnertoys »
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: 87 4runner brake issue
« Reply #1 on: Apr 02, 2012, 08:12:35 AM »
Sounds like there is still air in the system. A few questions for you.
Did you bench bleed the MC?
Where did you get the MC?
Were the MC and calipers new or rebuilt where did you get them? I have had problems with brake componets bougt at places like AutoZone, Kragen places like that.
Is this how you bled your brakes?
This is the proper way to bleed your brakes to avoid spongy brakes, etc...
"...This is from the FSM and it works great..."
1. Drivers side rear
2. Passenger side rear
3. Passenger side front
4. Drivers side front
5. LSPV (Load sensing proportioning valve) This is very important step if you still have this valve. If you do not know where this is located, it is on the PS rear mounted to the frame with a rod connected to the rear axle housing.
  • Turtle Points: 7571
  • Male Posts: 3,561
    • emsvitil's album
« Reply #2 on: Apr 02, 2012, 04:24:26 PM »
Took me hours to bleed my lines after replacing the rubber lines with stainless steel..
After I was sure that all the old brake fluid was out of the system, I used my own version of a speed bleeder (aquarium air line check valve) with aquarium airline......
Wrap teflon tape around the bleeder threads so that there's no way air can enter system.
Run the airline tubing from the bleeder screw (after check valve) back to the master cylinder.
You recirculate the fluid until there's no bubbles in the tubing.....
874runnertoys [OP]
« Reply #3 on: Apr 03, 2012, 05:14:35 AM »
YES i did bench bleed MC.
THE MC  and caliper are from trail-gear.
ya that's how i bleed it but do not have the LSPV ON THE 4RUNNER any more.
OOPS
  • Male Posts: 2,561
« Reply #4 on: Apr 03, 2012, 06:35:02 PM »
Are there any components that are higher then the MC (like the line lock and lines to it)?
Cheng Lo
  • Turtle Points: 271
  • Member since Apr '12
« Reply #5 on: Apr 03, 2012, 07:16:18 PM »
You might have to adjust your booster push rod.  Clearance between master cylinder piston and push rod is 0mm per FSM.
874runnertoys [OP]
« Reply #6 on: Apr 04, 2012, 09:17:34 AM »
No all lower then the MC
874runnertoys [OP]
« Reply #7 on: Apr 04, 2012, 09:18:42 AM »
Will look in to that thanks for the tips guys
Cheng Lo
« Reply #8 on: Apr 04, 2012, 08:45:03 PM »
Hope everything works out.  :beerchug:
Last post May 29, 2006, 08:26:58 PM
by 79coyotefrg
Last post Dec 08, 2008, 02:03:53 PM
by abeer
Last post Aug 03, 2009, 09:00:47 PM
by OOPS
Last post Nov 05, 2009, 09:41:16 PM
by wifesaysimadumbass
Last post Sep 05, 2012, 09:15:07 AM
by Cheesemaker
