Author Topic: Differentials  (Read 1841 times)
Mattinker
  • Turtle Points: -19
  • Member since Mar '05
Differentials
« on: Apr 01, 2012, 07:25:14 AM »
I did a search to try and find out what the four differentials I have are, '82 and '83. the two fronts are different, and one of the rears has a block that I don't recognise! Can anyone help me identify them, I have an Aussie locker to put in the front axle. I need to know which or the differentials I have is the strongest!
Thanks, Matt
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: Differentials
« Reply #1 on: Apr 01, 2012, 07:27:51 AM »
Mattinker [OP]
Re: Differentials
« Reply #2 on: Apr 01, 2012, 07:33:22 AM »
http://home.4x4wire.com/erik/diffs/
Thanks for your rapid reply, but, the diff on the front of the 83 isn't on the list! Maybe a European model, it looks upside down! Also any idea about the block on the rear? I can't take it apart yet.
Matt
Goldrush
  • Turtle Points: 145
  • Male Posts: 1,381
  • Member since Jan '10
  • wheelin!!
Re: Differentials
« Reply #3 on: Apr 01, 2012, 07:35:44 AM »
High pinion for sure! That's the third pic down! :)  :thumbs: that high pion is from an fj 80 style landcruiser
Mattinker [OP]
Re: Differentials
« Reply #4 on: Apr 01, 2012, 07:42:31 AM »
I could use that on the back and the rear on the front? My Aussie locker is for a Hilux 79 to 85. Does this mean that it's an fj 80 axle or are the interchangeable?
Thanks, Matt
« Last Edit: Apr 01, 2012, 07:50:06 AM by Mattinker »
Goldrush
  • Male Posts: 1,381
  • wheelin!!
Re: Differentials
« Reply #5 on: Apr 01, 2012, 08:21:41 AM »
If u have what's called a 4 cyl Aussie, ( I'm asumming that is what u have.) u can only use that in a 4 cyl style diff. The difference is carrier bearing size. So u need to match up the Aussie to the correct diff style. And I do not recommend putting the high pinion in the rear, they have a tendency to break. and the high pinion is one that came out of a landcruiser axle, that is correct. And they are interchangeable.
Mattinker [OP]
Re: Differentials
« Reply #6 on: Apr 01, 2012, 11:20:37 AM »
Thanks Goldrush,
Yes it's a 4 cyl Aussie, so I can put it in what's now the rear differential, I will use it in the front, and swap in one from the '82 when I change over the two vehicles!
Thanks again things are now clear!
Matt
cen-cal crawler
  • Turtle Points: 10
  • Male Posts: 690
  • Member since Mar '09
Re: Differentials
« Reply #7 on: Apr 08, 2012, 11:23:08 PM »
so whats the block for??????
||_________||_________||__TOYOTA_||
||_________||_________||__________|
Mattinker [OP]
Re: Differentials
« Reply #8 on: Apr 09, 2012, 04:13:11 AM »
I don't know, I haven't taken it appart yet!
Last post Jul 12, 2004, 02:53:28 PM
by 84runner
Last post May 19, 2005, 05:17:25 AM
by bluetoy84
Last post Oct 10, 2005, 06:59:17 AM
by 79coyotefrg
Last post Jun 20, 2009, 12:08:36 PM
by potter85
Last post Feb 10, 2022, 12:19:30 AM
by Barrymc
