Author Topic: 98 4runner sas questions?  (Read 1548 times)
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
« on: Mar 08, 2012, 05:11:53 PM »
I have a 98 4runner sr5 5 speed 3.4 blah blah blah. Anyways I'm looking at doing a sas on it some time in the next year or so. I have a few questions and I've been looking at builds but no one really shows or takes time to explain a few things. So here we go.
1. For steering, first off can I use a ifs bracket mount that marlin, allpro sell for the pre 95 trucks? How do you go about hooking up the colum to the ifs box, is it a custom job or can I take 2 steering shafts from a ifs rig and cut and weld and sleeve them to get it to work? Will my 3.4 ps pump and lines work with the ifs box or do I have mod a 22re/3.0 pump to fit and get custom lines?
2. Will the spring hangers from a ifs to sas style idea work? Can I put holes though my frame for the shackle tubes or should I go shackle mounts below frame?
3. What do I have to do to my oil pan and pickup and dip stick? From my understanding and correct me if I'm wrong I use the 3.4 t100 2wd stuff? I'll be buying new oem parts from toyota for this. I do not really want to cut and weld my oil pan and do hokey backyard stuff.
4. Rear suspension if I ever get sick of the factory link set up. What do most you guys run chevy 63s? are they enough to hold up the weight of a runner(I carry about 350-500 extra pounds around alot chain saw chains, tools, people dogs, hunting gear ect...) and will a standard chevy 63" mounting set up work like from datin fab or skys?
5. No really a question but what I'm planning is a 85 front axle with 4.30s and a elocker longs and marlin high steer going duals or at least right hand drop case. From what I remember seeing at bone yards the 3.4 t100 4wds had a pass side drop can I use their trans and tcase or is it something special they have?
Thank you guys for any tips links or ideas. I have 2 sas's under my belt on 3rd gen 4wd trucks so cutting welding ect... is not a issue I just don't have the time or tools to fab up my own parts I'd rather buy everything and take a week off work to sas it and get everything sorted out.
86 mini truck 18" rays
09 highlander
70 suburban
<3 Low range
  • Male Posts: 17
  • Member since Dec '11
Re: 98 4runner sas questions?
« Reply #1 on: Jul 02, 2013, 04:24:12 PM »
The axle width may not be wide enough. I used a FJ60 axle on my T100 on my SAS with 2 1.5 wheel spacers and the width came out well. The oil pan should be fine also
Last post Sep 16, 2005, 12:58:39 PM
by e_cliff
Last post Jun 07, 2006, 09:37:37 AM
by MiniSimp
Last post Apr 12, 2007, 11:08:11 AM
by 46&2
Last post Jun 08, 2011, 05:14:55 PM
by bigarms23
Last post Oct 31, 2012, 06:56:15 PM
by tgmaul88
