Author Topic: I do not even know  (Read 2307 times)
Jokeass-Wheelers
  • Turtle Points: -5
  • Male Posts: 429
  • Member since Aug '10
  • toyota 4X4
I do not even know
« on: Feb 08, 2012, 03:14:19 PM »
Ok so I got a 1982 Toyota with a 1991 Toyota motor in it and it runs really good bit when I'm driving down the road at about 1200 rpm it will it will idle funny Like high low high low high low if that makes sense I got the timing all right and all the wiring looks to be hooked up and so does the vaccume idk how to fix it it's like the motor kinda bogs down if I try to keep it at a steady 1200 in 1 2 3 4 5 but if I give it more gas it works just fine
11 Jokeass-wheelers 7
1985 Toyota 4runner 22re 4x4 5:29 38in tsl's
IF IT LOOKS LIKE A PIG SMELLS LIKE A PIG IT MIGHT BE A PIG
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • Member since Oct '07
  • low n slow
Re: I do not even know
« Reply #1 on: Feb 08, 2012, 03:19:30 PM »
22r or 22re? v6?
dropzone
  • Turtle Points: 7
  • Member since Feb '07
  • Drive a 1st Gen
« Reply #2 on: Feb 09, 2012, 01:18:56 AM »
22r or 22re? v6?
from his sig '22RE'
81 Toyota Trekker 221:1
Jokeass-Wheelers [OP]
  • Turtle Points: -5
  • Male Posts: 429
  • toyota 4X4
« Reply #3 on: Feb 09, 2012, 08:10:38 AM »
1991 22re 4x4 everything completely stock in the motor minus the header and flowmaster
Goldrush
  • Turtle Points: 145
  • Male Posts: 1,381
  • Member since Jan '10
  • wheelin!!
« Reply #4 on: Feb 09, 2012, 11:24:05 AM »
tps??  :dunno:
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #5 on: Feb 09, 2012, 07:00:12 PM »
Have you inspected the vacuum lines for cracks or intake tube(accordion section) for cracks, you could be getting non-metered air causing the engine to surge like as the ecu adds/reduce fuel.  Can you repeat the symptoms while stopped, or only with the engine under the strain of moving the truck?
1200rpms is also pretty low to be driving around in, in any gear.  You are well below the beginning of the 22re's power band, and your fuel mileage is likely suffering for it as well.
83 Crawler
  • Turtle Points: -13
  • Male Posts: 2,779
  • Member since Jun '09
« Reply #6 on: Feb 09, 2012, 08:49:31 PM »
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • low n slow
« Reply #7 on: Feb 09, 2012, 09:24:52 PM »
Haha read!!!
read what? in his original post it doesnt say what engine it is...... sorry i dont read everyones sig
83 Crawler
  • Male Posts: 2,779
« Reply #8 on: Feb 09, 2012, 09:44:58 PM »
same
johnboy
  • Male Posts: 53
  • Member since Mar '06
  • whats GOOD!
« Reply #9 on: Feb 11, 2012, 09:57:36 AM »
Other than vacuum lines and TPS, it cold be either your knock sensor, the weird little water sensor thing on the underside of the upper plenum or i believe the vacuum block on the back of the upper plenum.
1985 toyota STD cab locked up w/ 35's
http://www.whore4x4.com/
Ezekiel 25:17
The path of the righteous man is beset on all sides by the iniquities of the selfish and the tyranny of evil men. Blessed is he, who in the name of charity and good will, shepherds the weak through the valley of darkness, for he is truly his brother's keeper and the finder of lost children. And I will strike down upon thee with great vengeance and furious anger those who would attempt to poison and destroy my brothe
dgrant71
  • Turtle Points: 3
  • Male Posts: 236
  • Member since Apr '10
« Reply #10 on: Feb 12, 2012, 10:03:23 AM »
Check your intake, if there is a whole or crack in it that would cause it to run funny.
24SHORTIE
  • Turtle Points: 184
  • Female Posts: 313
  • Member since Apr '11
« Reply #11 on: Feb 12, 2012, 10:11:44 AM »
my 22re does that randomly usually when warming up or a little after.... still trying to figure out what the problem is!
  • Turtle Points: -5
  • Male Posts: 429
  • toyota 4X4
« Reply #12 on: Feb 12, 2012, 09:05:04 PM »
ya i only drive aroung at 1200 rpm because im in 4low and i got stock gears i only wheel my truck and it goes fast in 4low but  ya i am going to check the vaccume lines
UndefinedTaco
  • Turtle Points: -4
  • Member since Aug '11
  • Built by trial and mostly error
« Reply #13 on: Feb 12, 2012, 09:35:42 PM »
Sounds like fuel filter..i'd change it if its not new
it could be umetered air.or your IAC is sticking
or the ECT sensor is misreading(bottom right plug on block below throttle body on front engine)
83' Pickup "ShitBox" - more parts
92' Pickup "Doomed" - some parts
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
« Reply #14 on: Feb 13, 2012, 09:06:04 AM »
TPS!!!!!!
86bobbedtoy
  • Male Posts: 3,938
« Reply #15 on: Feb 13, 2012, 09:06:44 AM »
possable mas air, causing the tps to read wrong
realcamotoy
  • Male Posts: 36
  • Member since Oct '11
  • I'm having rock withdrawals!
« Reply #16 on: Feb 13, 2012, 09:10:04 AM »
And does it stop when you step on the brake?
  • Turtle Points: -5
  • Male Posts: 429
  • toyota 4X4
« Reply #17 on: Feb 13, 2012, 06:12:22 PM »
i will post a video of what it sounds like and when i step on the break it stops its onlydoes it when i am throttling up even at a dead stop it i rev up to that 1200rpm it does that
realcamotoy
  • Male Posts: 36
« Reply #18 on: Feb 14, 2012, 04:04:53 AM »
Both mine and my neighbors had done that in the past and after checking to make sure the vacuum lines were all connected and scratching our noggins for weeks i found out the idle adjuster on the side of our intake planeum was just a little out of adjustment. A little tweek in either direction should fix yours al well.
rage
  • Turtle Points: 26
  • Male Posts: 142
  • Member since Jul '06
« Reply #19 on: Feb 14, 2012, 11:37:30 AM »
Funny 22re idle surge, super common.
  Adjust tps properly(basicly make sure it gets IDL contact) so that you can properly set short circuit timing to 5 or 6 Btdc. Then set the Idle to 750 - 800... problem solved.
   When the Idle is to high, like 900ish, tps never gets IDL contact and without that timing cannot be properly set. And with that high idle, motor will surge at 1200, or when brakes are used, or both. Thats do to the IAC freaking out thinking your still idling. Kinda confusing, but just check what I said. I do that to 4 out of 5 22re that come through for smog repairs.
