heres a alternative to a GM alternator all together, and it takes the factory toyota plug... Just another option... http://www.davezoffroadperformance.com/store/electrical/batteries-more/high-output-alternator.html
One thing you need to consider with that alternator is that your factory whirring is meant for 60 amps. Bumping it up to 130 amps might have some un-desirable affects. I.e. melted wiring harness. If you go that route I'd recommend upgrading your wiring.
I assume that could be possible, although I have been running this alternator for a few years now with no problems,,, maby i should say knock on wood,,, haha
If your usage is below 60 amps than it should be fine. When you need for worry is when you start using more than 60 amps. The wire is meant to withstand 60 amps. When you add all kinds of power drawing accessories like rock lights bumping stero winch ect... That's when the wire will start to heat up and could potentially cause problems.
Like I said I guess that's possible,, although I do not know what my average usage is, although I have a 1000 watt amp, 2-10" subs w/ 6x9s etc, 12 rock lights,, 4-6" KC lights, roundeyes head light conversion, 9000lb Warn,, etc,, etc.... I have been know to use everything at once, although its not very often... Im not saying this is the best alternator option,, just its working good so far....
Started by Brandon Parts For Sale
Started by 95TacoTruck General 4WD Discussion
Started by blyota91 Engine
Started by gonepostal Toyota Pickup/4Runner Tech 1979-95
Started by lone walker Parts For Sale
