Author Topic: r150f input shaft question  (Read 2709 times)
EJMFS
  • Male Posts: 22
  • Member since Jan '12
« on: Jan 17, 2012, 07:38:28 PM »
Ok, so I'm new here in this forum so I can't post photos yet.  I believe what I have is an R150F but I haven't found any numbers on it yet.  It came from a 94 3.0v6 toyota pickup.  So I have the bearings and clutch kit for it and when I slid the pilot bearing over the shaft I realized that it fit really loose.  I know this isn't ok.  Also, the input shaft has some looseness when I wiggle it.  I am guessing this is not ok but I am not a transmission expert.  How much play is allowable in the input shaft?  It has a little bit of looseness in the shear direction but in the axial direction it is tight.  Any help from experienced people is appreciated.
Thanks
187unlimited
  • Member since Apr '19
Re: r150f input shaft question
« Reply #1 on: Apr 13, 2019, 03:37:53 PM »
a little play back and forth is normal. it does need some play as to not bind up when it gets hot. the up and down is what i would worry about. also those transmissions need the bearing retainers replaced with stronger units. Marlin makes them. and also the thrust washer between 2-3 fails and destroys the trans. i would recommend bearings, syncros and the stronger retainers and washers if you plan to abuse it. or if you just plan to drive it nicely probably just a front bearing. its easy to change. you just need a press. I recommend Redline oil as well. I use MTL gl4
Last post Dec 01, 2004, 12:16:00 AM
by dildinon
Last post Dec 06, 2006, 07:43:59 AM
by vfrrocks
Last post Dec 09, 2006, 07:30:47 PM
by yotaweelr
Last post Dec 09, 2019, 07:35:27 AM
by dewiseman
Last post Dec 26, 2022, 10:42:09 PM
by 2manytoys
