Author Topic: what are the pros and cons of lift blocks in the rear springs  (Read 12192 times)
81 toyota
  • Turtle Points: -2
  • Male Posts: 241
  • Member since Oct '11
  • 81 toyota detroit front spool rear 35x14.5 boggers
I started this thred because i have a 81 toyota that i want to give a little more flex... the previous owner added three leafs in the rear which made the truck flex like  :thumbdown:
 fortunetly the truck has teraflex shakles so it is ok off road... thats not the point
the question is what are the pros and cons of lift blocks.
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
you will get alot of axle wrap, but can ad a track bar.
alot of guys running chevy springs rear, run blocks
of course no one is a fan of blocks, but there not as horable as some say.
what springs are you currently running?
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
that's it
get some better springs.
hansi530
  • Turtle Points: 4
  • Male Posts: 412
  • Member since Sep '10
yea a whole lot more wrap i have 2 inch blocks i got axle wrap on the sand
88 custom cab: http://board.marlincrawler.com/index.php?topic=88026.new#new
shitlbuffout-A saying among 4x4 and off road enthusiasts. Its said after damage normally cosmetic to minor parts damage has occurred on there rig or vehicle. Shitlbuffout is :pokinit: will buff out as in the :pokinit: being the damage will buff as in painted over cleaned polished or "buffed" out.
  • Turtle Points: 452
  • Male Posts: 3,554
  • I'LL NEVER MAKE IT...
The benefit is that everyone will think you're a poser, the main drawbacks are axle wrap and that everyone will think you're a poser...
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Axle wrap you can taste, and you can always prove them wrong when they call you a poser.
BadnewsBob
  • Turtle Points: 9
  • Male Posts: 350
  • Member since Sep '11
I have them on mine with chevy springs, Got me the lift I needed. I don't have any problems with axle wrap yet. That don't mean I won't.
I don't really want them on the truck but for now they work great. My truck is not a poser truck, It'll go and dose. :twocents:
AE2 USN ret
No matter where ya go..... there ya are.
Hillbilly Offroad
84 xtra cab on 63" chevies and RUF 35" KM2s 22R 5 speed DTC 5.29s Locked front and rear.
yotacrawler1
  • Male Posts: 259
  • 1985, on wontons
yeah if u want more flex blocks wouldnt be the way to get it.
81 toyota [OP]
  • Turtle Points: -2
  • Male Posts: 241
whell problem solved i got a chanse to talk to my welding teacher about it (he use to go to call rocks and compeet) anyways he sad to jest take out the extra springs and run it like that.
  • Momentum Man
  • Lego Enforcement
FYI if you do decide to run blocks do not get aluminum the load on the ends will round them off and then not only will that create even more wrap they can come loose.
DAILYspec
  • Male Posts: 10
  • Member since Feb '12
something to consider, I guess I'll try to stay away from blocks.
Royota
  • Male Posts: 127
  • Member since Aug '12
  • Pacific Northwest 4x4
blocks will add a lot of stress to your axles and driveline and everyone hates them, but they are not remotely as horrible as people make them out to be. as long as you don't go over 3 inches or so on the block height then it won't have any real terrible effects and you will be able to fit larger tires in your wheel wells. I say go for it
May Bobby Long be forever immortalized in his work and deeds to the Toyota 4x4 community. Because of a select few including this wonderful man, none of us have to drive Jeeps. He will be missed.
4low4runner
  • Male Posts: 38
  • Member since Jun '11
  • Let it idle and crawl...
I run chevy 63 on my 4runner with 3 inch block been wheeling like that for 2 years no axle wrap everyone just over think not as bad as what everyone say
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
    • Placer County Crawlers
I've been running 3 inch blocks under my 63s for the past 7 years. It was daily driven for 3 years and been driven on the trail only for 4 years. Never had any problems with axle wrap or anything else. I would recommend blocks, as long as its not a heavy rig with a v8.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
BadnewsBob
  • Turtle Points: 9
  • Male Posts: 350
Something to chew on with this.   My stock 1977 Ford F150 4X4 LWB has lift blocks on it installed by Ford, If they were as bad as some people make them out to be, would a major company install them new? Things to ponder I suppose.
AE2 USN ret
Hillbilly Offroad
superyota
  • Turtle Points: 71
  • Male Posts: 3,362
  • what happened?
Funny you mention that, my 05 dodge ram 2500 TD also has 2 inch lift blocks in the back from the factory.
ABD Motorsports
#4475
KK6QDW
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
Most new trucks have "lift" blocks in the rear. They also have stiff leaves that aren't meant for offroading and a long wheelbase. Also a lot of them have overload springs on top of the pack which would help with axle wrap.
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Most new trucks have "lift" blocks in the rear. They also have stiff leaves that isn't meant for offroading and a long wheelbase. Also a lot of them have overload springs on top of the back which would help with axle wrap.
Exactly!!!!
BadnewsBob
  • Turtle Points: 9
  • Male Posts: 350
Good points.
AE2 USN ret
Hillbilly Offroad
66cobra
  • Turtle Points: 34
  • Member since Mar '08
well now,  this is an informative post i have 63s back sits a little lower think it would be ok to put in 2" blocks and move the fat ol leaf to the top
it's not me, it's you
Nimyad
  • Turtle Points: -1
  • Male Posts: 1,138
    • Buy me a cigar
Nope. That'll be awful for ride. How newer overloads on top of the pack are, is that it is a very arched spring that hits a mount above it (landing pad for lack of a better term) and that begins to carry the load or present wrap. If you put a overload that goes under the pack on top then it will severely limit the packs performance and most likely life of the springs.
66cobra
  • Turtle Points: 34
Thx that might have been a stupid question
Exhaust Pros and Cons
Last post Aug 15, 2012, 02:49:46 PM
by BigMike
Last post Oct 14, 2004, 05:42:09 AM
by Fireimp141
Last post Nov 07, 2004, 06:54:01 AM
by UNBREAKABLE
Last post Jul 05, 2007, 01:53:54 PM
by CrawlerBrennan
Last post May 24, 2012, 11:54:45 PM
by Wiscolandcruiser
