Author Topic: HILUX FRONT AXLE HOUSING 1982  (Read 1579 times)
82 HiLux
  • Trade Count: (0)
  • Turtle Points: 81
  • Male Posts: 750
  • Member since Dec '06
  • its beer thirty!
« on: Dec 10, 2011, 05:49:09 PM »
 I have for sale a bare front axle housing off of an 82 toyota pickup.  All of the differential studs are good.  The drivers side leaf spring perch has the spacer welded on to make the truck sit level  (toyota designed the front axle with the passenger leaf spring perch partially up on the differential, so you need a spacer on the drivers spring perch to make the truck sit level).  There is a bracket weded ontop of the differential part of the housing for using a steering stabilizer with a hi-steer setup.  It places the the steering stabilizer schock BEHIND the tie rod when you have hi-steer.  The housing has the big bracket for the factory torque arm cut off.  It has the stock shock mounts and steering stops on the housing.  No rust on the knuckle ends.  No metal inside of the housing.  The front differential cover is in great shape, no dents.  The housing has the fill plug and drain plug included.  Its dirty from the truck it was on.  Ill sell it the way it is for $80 firm, or if you would like, I will clean it for an additional $20.
Located in Santa Rosa, CA.
$80 as-is (dirty)
$100 cleaned
My price is firm.  100$ for a front axle housing is a great deal.
If you want to buy it, the best way to reach me is my cell phone 707-548-4678.
If I dont answer, leave me a voicemail with your number and I will call you back as soon as I get the message. My name is Tim.
Thanks for looking!
« Last Edit: Dec 10, 2011, 05:58:38 PM by 82 HiLux »
82 HiLux [OP]
  • Trade Count: (0)
  • Turtle Points: 81
  • Male Posts: 750
  • its beer thirty!
Re: HILUX FRONT AXLE HOUSING 1982
« Reply #1 on: Dec 10, 2011, 06:31:35 PM »
  • Momentum Man
  • Trade Count: (0)
  • Turtle Points: 759
  • Male Posts: 13,855
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #2 on: Dec 19, 2011, 02:09:12 AM »
I know someone that's looking for one, do you ever get down to So Cal or know someone coming down? Oh and is it straight/unbent, his is slightly bent and he has to replace the seals all the time.
Last post Dec 04, 2003, 02:01:17 PM
by Brandon
Last post Sep 10, 2008, 07:12:02 PM
by Lonestar Honcho
Last post Mar 06, 2010, 10:33:54 PM
by crawlerdad
Last post Sep 29, 2009, 09:02:10 PM
by 79coyotefrg
Last post Dec 16, 2009, 09:29:18 PM
by motormouth559
