Author Topic: Fuel pump prime loss??  (Read 2451 times)
Zs Confederate Toy
  • Turtle Points: 2
  • Male Posts: 1,146
  • Member since Mar '11
« on: Dec 04, 2011, 09:43:04 PM »
I have a carbed 22r in my 87 PU. Over the last few weeks the fuel pump seems to lose its prime or something. If it sits more than a day its is a bear to get started. I could sit there all day and crank till the battery dies. If I pump the throttle it wont run but if I leave the throttle closed it will catch and run rough until I try to give it some gas and then it just dies. If I blow the fuel line out with air and dump a little fuel in to the top of the carb it will fire right up and run fine till it sits about a day.The filter and pump are brand new and the carb has a recent rebuild. Motor is also a new rebuild. Less than 5k
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: Fuel pump prime loss??
« Reply #1 on: Dec 04, 2011, 10:05:46 PM »
Winter fuel evaporates easier, and the fuel in the carb may have evaporated out.
Have that problem with my 64 Valiant (even if it's not winter)
I added an electric fuel pump to prime the system.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #2 on: Dec 07, 2011, 12:18:21 AM »
The carb may be draining into the engine, make sure to check this since the fuel can get past the rings and into the oil.
ky-homelite
  • Member since Oct '11
« Reply #3 on: Dec 29, 2011, 03:21:17 PM »
Alright, if this is the case, how do you fix it? I seem to have the same problem as the OP. Generally on a cold morning, I'll pump my carb 6-8 times and it'll fire off and run fine. I don't seem to be having fuel get past the rings into the oil though.
Zs Confederate Toy [OP]
  • Turtle Points: 2
  • Male Posts: 1,146
« Reply #4 on: Dec 29, 2011, 05:06:44 PM »
My problem ended up bein a shitty Checker fuel pump. I changed it and problem solved. Fires right up everytime
ZACH
87 Rock Rat X
Trail Junky
Last post Mar 31, 2005, 07:34:15 PM
by alwayzbroken
Last post Jul 05, 2005, 01:02:34 PM
by stillakid
Last post Mar 31, 2007, 09:35:41 AM
by robrub00
Last post Sep 04, 2011, 08:21:50 PM
by Toyospearo
Last post Jun 18, 2013, 09:52:46 PM
by toyodaaddict
