Author Topic: 4low no reverse!!!  (Read 2160 times)
tyesman
  • Turtle Points: -5
  • Male Posts: 40
  • Member since Mar '11
4low no reverse!!!
« on: Aug 09, 2011, 09:04:07 PM »
Have 86 runner 22re, reverse will not work when 4low. Everything else works fine. Dont see that being important but maybe usefull.. Its bugging me what could be wrong???
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
Re: 4low no reverse!!!
« Reply #1 on: Aug 09, 2011, 09:15:34 PM »
Transmission shifter hitting your Tcase shifter?
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
  • I'm not being rude. You're just insignificant.
« Reply #2 on: Aug 09, 2011, 10:05:04 PM »
totally what i was thinking lol...
Those are some huge welds!
Tillamook, OR
tyesman [OP]
  • Turtle Points: -5
  • Male Posts: 40
« Reply #3 on: Aug 09, 2011, 10:11:03 PM »
I dont feel like anything is hitting i have to recheck and recheck. It has a 3 inch body lift can that add to the problem?
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #4 on: Aug 09, 2011, 10:19:46 PM »
That usually causes more problems with the t-case shifter than with the tranny shifter.
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
« Reply #5 on: Aug 09, 2011, 10:20:46 PM »
body lift is prob the problem actually... My friend had a body lifted 1st gen that did the same thing. in low, you would throw it in reverse and the shift boot would pull it into neutral in the tcase..
So i guess my next question would be, without moving the 4wd lever can u put it into a forward gear and move?
to me it sounds like your getting pulled out of gear in the t case
Tillamook, OR
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #6 on: Aug 10, 2011, 08:27:34 AM »
Take the shifter boots off and see if that helps.
RainierToy
  • Male Posts: 49
  • Member since Aug '11
« Reply #7 on: Aug 10, 2011, 11:46:09 AM »
I have a buddy who has no shift knob on the tcase so it doesnt knock it into neutral..
Party
tyesman [OP]
  • Turtle Points: -5
  • Male Posts: 40
« Reply #8 on: Aug 10, 2011, 08:36:41 PM »
Damn shifter i carefully look at it and played with it. Its the lift like you guys said and the shifter putting it back in neutral... U guys are great... Worried sick man.... Thanks.
4RunnerChevy
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #9 on: Aug 10, 2011, 08:51:51 PM »
 :twocents:  Make sure there is plenty of clearance, between body and shifters.  If your under heavy load, your body may shift for you, and send you into a situation.
RainierToy
  • Male Posts: 49
« Reply #10 on: Aug 11, 2011, 01:56:16 PM »
Always my friends truck a 2wd body on a 4x4 frame with a very very small body lift.
Party
Last post Dec 07, 2005, 06:12:18 PM
by psychotoy
Last post Nov 09, 2005, 03:10:16 PM
by 81_toyota
Last post Mar 06, 2007, 10:11:59 PM
by Jeffe 81
Last post Apr 03, 2018, 08:41:11 PM
by 92.4runner
Last post Jul 08, 2021, 07:03:23 AM
by Ritchie
