Author Topic: spark plugs  (Read 2642 times)
Michael Wollinsky
  • Turtle Points: -9
  • Male Posts: 137
  • Member since Jul '11
  • rocks arent as hard to clean as mud
spark plugs
« on: Jul 26, 2011, 12:20:55 PM »
Well had a great day I decided to change my spark plugs the first one was OK to get out but the second one was difficult until it snapped off so all day I've been trying to get it out and I still haven't been able to would you think it would be easier tear the motor down?
Hand built and driving daily
Tyler82toy
  • Male Posts: 81
  • Member since Jun '09
Re: spark plugs
« Reply #1 on: Jul 26, 2011, 04:17:09 PM »
probally not what motor is this? did you try soaking the plugs with some pb blaster?
1stgenboy
  • Turtle Points: -2
  • Member since Mar '05
Re: spark plugs
« Reply #2 on: Jul 26, 2011, 08:28:39 PM »
One needs to allow an aluminum head to cool before trying to pull plugs.  Otherwise the spark plug might become galled.  This is where the aluminum sticks to the steel of the spark plug almost like it is welded.  likely it will come out once the head is cold with the threads stuck to the plug.  If so, you can use a heli-coil if you have access to the hole.
1stgenboy
Zs Confederate Toy
  • Turtle Points: 2
  • Male Posts: 1,146
  • Member since Mar '11
Re: spark plugs
« Reply #3 on: Jul 26, 2011, 08:43:42 PM »
When you put it all back in use anti sieze so itll be easier to pull next time
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
Michael Wollinsky [OP]
  • Turtle Points: -9
  • Male Posts: 137
Re: spark plugs
« Reply #4 on: Jul 27, 2011, 06:26:29 AM »
It's a 22re I let it cool all night got up to change them yea the idiot who had it before me didn't use anti sieze
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
Re: spark plugs
« Reply #5 on: Jul 27, 2011, 11:22:01 PM »
If you mean the bolt-like area that socket slides over on the plug broke free from the threaded section, I don't think you have much of a choice other than pulling the head.
If this is your first 22r-e rig, you should be able to have the head off in about 2-3hours depending on how much time you spend labeling/mapping out the parts as you remove them.  Here is a link to a '93 FSM.  If you haven't worked on Toyota's before, never pry anything off.  Toyota's tend to have hidden bolts, so if the part doesn't come off easily, you have likely missed a bolt or two.  Two main ones on the 22re is the bolt that bolts the timing cover to the head(under the pool of oil in front of the cam gear).  The other is a long allen headed bolt that goes through the intake manifold to the head.  It doesn't look like it should, but it does.
  • Turtle Points: -9
  • Male Posts: 137
Re: spark plugs
« Reply #6 on: Jul 28, 2011, 08:23:44 AM »
Thanks for the info yea I'm gonna try to some how lable all the vac hoses so I don't cross them but I'm gonna start Monday cause I'm going on vacation today
RockRescue
  • Member since Feb '06
Re: spark plugs
« Reply #7 on: Jul 29, 2011, 02:38:40 PM »
i had this happen to me before   i just got a big easy out  and was able to get the threaded portion out .
  • Turtle Points: -9
  • Male Posts: 137
Re: spark plugs
« Reply #8 on: Jul 31, 2011, 12:28:10 PM »
Tried broke every tool :rivers: we tried to put on the easy out there's a guy down the road from me that machines engines gonna take the head off I mite as well put a new set off guides for the timing belt on to
Snowtoy
  • Male Posts: 2,583
Re: spark plugs
« Reply #9 on: Jul 31, 2011, 04:44:13 PM »
If it is a 22re you have a timing chain, might as well and replace the chain and get a new timing chain kit, and not just the plastic guides.
If you have the 3.0, you should pull both heads, have them both serviced, as well as replace a number of other items.
Last post Mar 17, 2010, 07:26:35 PM
by joeycool00
Last post Jan 24, 2008, 09:29:43 AM
by acerbis
Last post Jun 19, 2009, 08:29:09 PM
by emsvitil
Burnt ceramic on spark plugs
Last post Feb 01, 2019, 01:35:49 PM
by V-Man
Last post Mar 06, 2019, 03:44:53 PM
by Gnarly4X
